What Happened???
Old Jul 12, 2012 | 04:14 PM
2000silverbullet's Avatar
2000silverbullet
Why not spend the $300 for air bags to make the truck work for your application? I understand the theory that you shouldn't have to, and there's no doubt the springs are softer than previous years, but suffice to say there are other options (i.e. mfr's). And thankfully, there's aftermarket options, so you can make the best truck out there, the best truck for you.
I thought the factory stereo sucked, I upgraded it. Alllll better.
Old Jul 12, 2012 | 04:21 PM
Tom's Avatar
Tom
Not really sure about this one.
Modern trucks are rated to tow more, haul more, and do more than they ever have at any point in history. If you loaded a truck 20 years ago with the capacity the newer ones have it would be badly overloaded. Doesn't matter if it squatted less, they were simply not meant to carry the weight. Less power, worse transmissions, less capacity, and worse efficiency.
What we have today is more choices. You can still buy a stripped down work truck that has vinyl seats, floors, and power nothing. But what you couldn't get twenty years ago were luxury heavy duty trucks that had many of the amenities found in premium cars. I have yet to see or hear of something that could legally be done with an older pickup that a newer one can't. And squatting a few inches under a load just doesn't count; this is the way a suspension is supposed to work. The class 8 KW I used to drive would squat some with an airbag suspension when loaded to capacity. Was my T-600 with its 15-liter Cat diesel not a real truck either?
Times change, and vehicles change with the times.
Old Jul 12, 2012 | 04:25 PM
CornTruckDriver's Avatar
CornTruckDriver
Like I always said , they were great in 1970
Old Jul 12, 2012 | 04:38 PM
rob92761's Avatar
rob92761
Here is my biggest dilemma. Hook truck to trailer. Trucks sag in rear end. Go past the state patrol or any weigh station. Try to explain to the officer why your truck is sagging! Frist thing out of their month you must be overload. Then a trip to scale. Then you know what happens.
And for you guy that pull campers yes you don't have to stop at weigh station or worry about the state patrol. I also have a camper. When pulling a camper you are considered an RV and do not need to stop at weigh stations
But when it comes to moving constitution equipment around the state patrol has no patience
Old Jul 12, 2012 | 04:45 PM
rob92761's Avatar
rob92761
When you spend $45000.00 plus dollars for a truck why should you have to spend $300.00 more for air bags?
Don’t get me wrong I have already upgraded my truck; titan tank (who ever decided to but 26 gallon tank on a truck should be shot) also put timbern SES on. But why!
Old Jul 12, 2012 | 04:50 PM
2000silverbullet
Why'd you put the titan tank in? The factory one wasn't sufficient for you. Same principle, different part....
I understand your point though, it's the way it is....
Old Jul 12, 2012 | 05:04 PM
rob92761's Avatar
rob92761
Fill up three times a week for one. Also get out in some areas were there is no fuel available.
If an aftermarket can design and install a big tank why can't ford?
Old Jul 12, 2012 | 06:41 PM
Maxium4x4's Avatar
Maxium4x4
Good idea, just like a spray in bed liner, Ford could offer an extended range tank.
Old Jul 12, 2012 | 06:53 PM
FTE Herman's Avatar
FTE Herman
Guilty as charged. I just had 60 large laying around and I wanted to fit-in with my local farm community. Unfortunately, it didn't entitle me to receive any of those farm subsidies that would have helped me better afford the truck; heck I can't even write it off on my taxes even though I use it to travel to my place of income gathering.
jdadamsjr's Avatar
jdadamsjr
We posted about this a while back... think the small fuel tank on the sb is so they can keep it under 10k gvwr AND legally give you some payload...
if not, they would have to certify it for more than the 10k gvwr and they don't want to do that since MANY would complain now they are required to get commercial licenses over 10k....
Old Jul 12, 2012 | 08:21 PM
farmer duke's Avatar
farmer duke
As far as the farm subsidies, they don't even come close to helping pay for the cost of putting the crop back in the ground or better yet the cost of farm machinery(which the epa has their hands on too). With $700/ton for fertilizer and $3.50 diesel and then you have a pickup go down and buy a 2012 F-350 to replace it only to find out it won't handle anything without putting another $300+ for airbags. So don't go there on the "farmers are rich with their subsidies" routine. It's getting old!
Old Jul 12, 2012 | 08:55 PM
rob92761's Avatar
rob92761
So 25 more gallon of fuel (titan tank) at about 7 pounds per gallon (175 pounds) and then the extra 100 pounds for plastic tank you would be lucky if you have 300 pounds in it totally. Ford says the payload 3290 pounds for 250 CC SB. So you would lose 300 pounds of payload for the extra travel distance let alone the less stopping when pulling. IMO the pros out way the cons. I wish ford would have put a bigger tank in from the factory it does not have to 50 gallons but 40 would have been nice.
Old Jul 12, 2012 | 09:41 PM
  #28
Tom's Avatar
Tom
Don't think anyone ever said that. You could give me a quarter which would help me better afford a truck...that doesn't mean I'm going to get rich off of it.
Old Jul 14, 2012 | 02:10 AM
  #29
mrjc's Avatar
mrjc
The F350 is the new truck, when one thinks of hauling. I too wished mine would sag when I hitch up my 5er (2500 lb pin weight) it does not touch the overloads, pulls like the old red masey furguson tractor
Old Jul 14, 2012 | 06:22 PM
  #30
cirrus365's Avatar
cirrus365
You kids get off my lawn!!!!
