Sponsored by: Real Truck
Engine coolant disappearing
Old Jul 11, 2012 | 08:41 PM
psvienneau's Avatar
psvienneau
My 2001 F-250 SD 5.4L 4X4 coolant keeps getting low every few months it is down by a 1/2 gallon, and I don't see any leaks or smell antifreeze,there is no unusual amount of water or vapor coming from the tail pipe,any thoughts would be appreciated.Thank You
Old Jul 11, 2012 | 09:10 PM
redford's Avatar
redford
FTE Leadership Emeritus
At this point you need your cooling system pressure checked. It cost a few bucks, but in the long run is probably cheaper than blindly throwing parts at it to solve the issue.
Old Jul 11, 2012 | 09:32 PM
psvienneau's Avatar
psvienneau
Redford, Thanks for that info, I'll have a friend of mine check the pressure in the system.
Old Jul 12, 2012 | 12:13 AM
redford's Avatar
redford
Good luck finding the issue. Let us know what you find.
Old Jul 12, 2012 | 02:38 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Just uploaded this today. Not even released yet.
You can do the pressure testing yourself if you want.
If your friend can do it no prob, but a shop will charge you. This method is free (except the initial deposit) and you get results in just a few hours, plus the satisfaction of knowing you did it yourself.
Checking the Cooling System for Leaks - YouTube
TruckoffFord
May 28, 2016 09:08 PM
makohon
Sep 24, 2008 07:18 PM
FHI-prez
Feb 23, 2005 02:28 PM
LongHorse
Sep 22, 2004 09:55 PM
