Aeroforce Interceptor Question - temp readings
Old Jul 13, 2012 | 08:34 AM
grec-o-face's Avatar
grec-o-face
Originally Posted by mueckster
Ken (woodnthings) mounted his coolant temp sender in the coolant bypass filter housing. He said the temp readings are still pretty accurate there. I have mounted mine there also, but haven't finished the wiring up yet. I will get that done this weekend.
I'm using the Carquest housing, so I only have two ports.
Old Jul 13, 2012 | 08:44 AM
mueckster's Avatar
mueckster
You could add a male run tee at the waterpump or the inlet of the filter housing to add the sender.
Old Jul 13, 2012 | 10:10 AM
grec-o-face
That's what I was thinking too. Then I just need to find a place to mount the gauge.
TOP Pillar - Pyro
BOTTOM Pillar - Boost
COLUMN: Aeroforce
Old Feb 15, 2013 | 01:46 PM
grec-o-face
Update
Yes, It's several months later.
I've added a stand alone coolant temp gauge. My readings vary quite a bit from the OBD based Aeroforce numbers. Sometimes I see a 20* difference, other times, it's within 2 or so degrees.
Most of the time I'm seeing around 170* with ambient temps under 35*. When loaded up a little it'll rise - but not much. I've only seen the needle tickle the 190 mark once.
PICS:
Hitagain
Mar 22, 2016 07:19 PM
bcaughhorn
Jul 2, 2015 06:35 PM
hornychief
1997 - 2003 F150
Jan 28, 2014 08:23 PM
Sqidget
6.7L Power Stroke Diesel
16
Feb 6, 2013 10:41 AM
usafstud
1997 - 2003 F150
Dec 19, 2010 10:17 PM
