Trailer running lights hook-in?
Old Jul 11, 2012 | 08:09 AM
Dark_Horse1's Avatar
Dark_Horse1
Trailering
I have a '02 Exp that came with the heavy duty tow pkg. (7 pin connector). I am hooking up the brake controller to the factory supplied plug. The controller has 4 wires which go to the harness plug but the harness plug has a 5th wire for illuminated lights (running lights).
Where is the best place for this wire to be tied into? Should I just find a source for lights somewhere in the dash and splice it in? Or is there a definitive location for this wire?
The instructions that came with the harness say nothing about it.
Thanks in Advance.
Steve
Old Jul 11, 2012 | 08:54 AM
alwaysfords41's Avatar
alwaysfords41
When you say brake contoller, are you talking about an electric brake controller under the dash or are you just talking about the trailer plug? I suspect the latter. Any trailer plug has running lights on it, the brown wire in is the running lights. The green is the right stop/turn, yellow is left stop/turn and white is ground. The 5th wire (blue) in a 5 pin is the brake signal for trailers with electric brakes, or aux power if no electric brakes. The 7 pin has brake, aux and back up capabilities.
Old Jul 11, 2012 | 09:07 AM
Dark_Horse1
Trailering
Im actually talking about the brake controller. The factory supplied a plug for it and the controller has 4 wires (power, ground, brake, stop light) and the plug for the underdash harness has 5 wires ( the same 4 as the controller plus 1 labeled illuminated lights). I'm trying to figure out if that wire needs to go somewhere specific or just splice it into somewhere in the lighting harness.
Old Jul 11, 2012 | 09:28 AM
alwaysfords41
I think that illumination it is talking about is illuminating the controller itself. The running lights are powered by the 7 pin at the back of the truck.
Old Jul 11, 2012 | 09:42 AM
Dark_Horse1
Trailering
ok - that makes sense. I have never seen that before (had the same controller on a chevy proir and it only had 4 wires).
I guess I will find out when I plug the trailer in - lol!
Thanks
Old Jul 12, 2012 | 02:18 PM
heymrdj's Avatar
heymrdj
That pin is if you have a fancy illuminated digital brake controller, if i remember right the illuminated pin feeds from your interior light dimmer, the same one that controls brightness of all your lights on the dash/radio. If you just have a simple dialer unit or something like that, they are generally 4 pins because they either don't have displays or their displays don't have controllable brightness.
SpeedThrills
All Things Towing
Feb 1, 2018 08:42 PM
RxWarrior
Jan 3, 2016 04:04 PM
dlturner00
Aug 21, 2009 07:23 AM
buffalobob
13
Aug 25, 2008 07:49 PM
oppy
All Things Towing
16
May 18, 2004 10:49 AM
