replacing my rear
Old Jul 10, 2012 | 08:45 PM
98 blue oval's Avatar
98 blue oval
replacing my rear
i got a 98 f150 8.8 3.55 well it decided to quit i dont have a pot to **** in or a window to throw it out. n every junk yard think there sellin gold the cheapest i found with in a 50 mile radius is 650 well i found a rear out of a 93 same gears 8.8 my question is will it work if not ill bit it and spend the loot but for a 150 n down the street from me can it word its out of a 93 f150 if anyone can help i dont think it will but hoping it will thanks
Old Jul 11, 2012 | 10:34 AM
batchman's Avatar
batchman
I would guess (and only a guess) that the full housing would be different but the gear set would be the same. You don't mention what's given up but if it's the spider gears or ring/pinion you might try double checking part numbers for sub-components like bearings and seals at rockauto or ringpinion.com to prove they're the same.
8.8 31 spline has been stable for a very long time. On the other hand not even the wheels are the same from OBS to new.
Good luck,
- Jeff
Dan92
Mar 9, 2011 11:47 AM
spanky1071
Sep 14, 2004 04:32 AM
89broncobob
1978 - 1996 Big Bronco
Aug 15, 2003 04:55 PM
hankhankster
May 7, 2002 01:33 AM
