E4OD Cooler
Old Jul 11, 2012 | 07:12 PM
86F150302's Avatar
86F150302
This^^^^
Run 1 big one over 2 small ones.
The Long cooler. Part #47391 is pretty much the same as the PSD cooler minus a couple brackets.
Ford buys the PSD coolers from long.
Old Jul 11, 2012 | 07:19 PM
blkF250HD's Avatar
blkF250HD
I'm always hesitant to buy a salvage yard cooler for anything. For all you know the truck it came off of grenaded the trans and now there's all kinds of crap in the cooler.
Old Jul 11, 2012 | 07:22 PM
Evan_P's Avatar
Evan_P
Never thought about that. That kit from Oreilly seems like a good idea. Just replace my current old one with the new one?
Old Jul 11, 2012 | 07:30 PM
norfolknova's Avatar
norfolknova
Yes, remove the old one, you will lose a few ounces of trans fuid. Install the new one. the kit comes with the push through cinch typw mounts. I have used them with out any issues an many vehicles. The kit comes with 4 square rubber pieces. Stick these on the back of the new cooler so it doesn't rub on the a/c condenser. Loose your radiator fan shroud so you can put your hand between the fan and the radiator. push the 4 plastic rods slowley through the cooler the condenser and the radiator fins. Put the small round plastic hold downs onto the back of the plastic rods till they are tight. trim off the excess plastic rods. reinstall radiator shroud. Install the rubber hoses from the new cooler to the trans cooling lines. Start engine, check for leaks and check trans fluid level
Matt
Old Nov 17, 2012 | 09:40 AM
Encho's Avatar
Encho
The Southernmost Mod
Hey guys, what do you think of this one? will it work fine? does it have all the parts I will need?:
B&M 70268 SuperCooler Automatic Transmission Cooler : Amazon.com : Automotive B&M 70268 SuperCooler Automatic Transmission Cooler : Amazon.com : Automotive
Old Nov 17, 2012 | 09:46 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
that's the one i run.works very well.comes with what you need,though you want to keep it away from whatever you put it in front of so there is a gap.so id toss the plastic tie things and just rig up your own metal brackets.
Old Nov 17, 2012 | 10:44 AM
Encho's Avatar
Encho
Can you post a picture from farther away? I would like to have a more clear idea of were to mount it.
Old Nov 17, 2012 | 10:23 PM
Encho's Avatar
Encho
I also found this one, it has the same dimentions, so what do you think about it?:
Amazon Amazon
Hmmm... taking a closer look it has a lot less plates than the B&M... I guess B&M is the way to go.
Old Nov 17, 2012 | 10:43 PM
FORDF250HDXLT
found this one,when i was installing fog lights.i had her stripped down ready for the body shop for repair and fresh paint.should be what your after.
as far as exact custom made brackets.you just hold it up there,and see what you have kicking around that can be bent to work.
that one you linked to from jegs is good too.wouldn't be surprised if it was by b&M or perhaps same exact cooler anyway.it doesn't take much to cool an auto trans with a locking converter.them days are long gone since the c6.
remember ideal trans temp is 175.it's very easy (and often done) to over cool 'em and be too far below perfect temps.
she's got a min operating temp just like your engine.always best to install a trans temp gauge first.many people don't need aux coolers.
Old Nov 18, 2012 | 12:12 AM
Encho's Avatar
Encho
I already have some sort of generic cooler (and fin and tube at that too...) and I'm very sure it isn't doing the job, we get +82 most of the days around these parts, and things get really hot very fast, so overcooling isn't a worry to me.
rgnprof
51
Dec 12, 2017 10:24 PM
BigDog83
Aug 14, 2009 08:18 PM
taylorjgreen
Oct 26, 2008 05:14 PM
mybigredford
Jun 14, 2004 12:12 PM
oregon250
Aug 5, 2003 06:50 PM
