Ford Passenger Van Seat Mounts info Needed
I need to know some seat mounting information. On a late 90s to 2003 Passenger van, what is the front to back center to center bolt placement on the mounting brackets?
Each seat has 4 mounting brackets, with 2 bolts holding each to the floor. This os for the bench seats behind driver and passenger buckets.
Can someone measure the front to back, bolt center to center measurement for me?
Would be a great help, thanks.
Jon
Jon
Sorry it took so long but here's the measurements for your seats from a 15 passenger (4 bench seats). Starting point is the rear left most bolt of the drivers side seat box, from there it is 23'' 1rst bracket, 34'' 2nd, 56 5/8 3rd, 67 5/8 4th, 89 3/4 5th, 100 3/4 6th, 120 3/4 7th, and the last is a 4 hole bracket @ 131 7/8 and 134 1/2. The holes on the left side are all in line with each other. Passenger side starting point is rear left most seat box bolt, 23 1/4 1rst, 34 1/4 2nd, 56 5/8 3rd, 67 5/8 4th, 89 3/4 5th, 100 3/4 6th, 120 3/4 7th, 131 7/8 & 134 1/2 last. The 1rst 2 brackets are 11'' from step, the next 4 are 16 1/4'' from step and the last 2 are 11'' from step. If you lay a straight edge from the starting point to the rear the inside holes on the 1rst two, the outer holes on the next 4 and the inner holes on the last 2 will all line up. If you have a 12 passenger all will be the same just deduct the distance between the 3rd row and 4th. Hope this helps.
Thanks hillbilly, I really appreciate it. The long bench in the back, is yours a late model van? mt long seat uses 4 brackets with 2 bolts each.
On the shorter benches can you measure any one of them for the bolt hole centers of all the bolts. Just need a center to center of the bolts front to rear and side to side....no particular one and no specific refrence to the van.
Just the centers of the bolts side to side and R to R.
Thanks...Laying out a floor....in a cargo van.
Jon
Jon
motorcarmike
03-10-2016 11:56 AM
Reef Tech
08-11-2014 12:52 PM
Pollydog
02-21-2011 10:50 PM
goodwrench
05-05-2010 07:50 AM
al_e._gator
07-10-2005 10:19 PM
