Dual fuel pump EFI system
Old Jul 8, 2012 | 11:20 PM
junkyardjeff's Avatar
junkyardjeff
I am chasing down a hard cold start issue in my 88 bronco and wondering why Ford came up with the dual fuel pump EFI system,it just seems like there are too many parts that can go wrong and a pain it trying to figure it out. I might be gaining on the problem but will find out after it sits all night,I was thinking about converting it to the single pump system and wish I had done it.
Old Jul 9, 2012 | 10:00 AM
Conanski's Avatar
Conanski
The dual pump + switching valve was a transition from the low pressure system needed for a carbed motor to the high pressure system needed for EFI. Thankfully that mess only survived for a couple years and was replaced with the much simpler in-tank high pressure pump system by 1990. With the dual stage system that you have pressure problems are often traced to the switching valve.. assuming both pumps are working normally.
Truckman8719
Jan 4, 2018 10:27 AM
Shark Racer
Dec 30, 2011 07:43 PM
lazerf250
Jun 18, 2009 06:39 PM
narcolepticpug
Mar 20, 2009 11:52 PM
jwtaylor
Oct 30, 2001 11:22 AM
