what is wrong
Old Jul 8, 2012 | 01:42 PM
ken1960's Avatar
ken1960
what is wrong
what is wrong with this truck i get about 12.9 mpg i have had it back to the dealer for the lattest recall it has 331 gears 6.7 diesel 3/4 ton. does anyone no what could be wrong
Old Jul 8, 2012 | 01:47 PM
kper05's Avatar
kper05
What is your driving style?
Are you stock with stock tires?
Where do you get your fuel?
If you are empty most of the time and spend a lot of time in stop/go traffic with short trips, your truck may not be able to complete an active regeneration properly.
This will negatively affect MPG.
Have you ever received a "drive to clean exhaust" message?
Old Jul 8, 2012 | 02:49 PM
ken1960's Avatar
ken1960
no i have not recived one of those messages ,i have recived a cleanining filter in progress.i drive in country alot .i dont abuse the truck, an i buy fuel were ever i can get it .
Old Jul 8, 2012 | 03:07 PM
rob92761's Avatar
rob92761
how new is truck mileage wise?
Old Jul 8, 2012 | 04:37 PM
Andrew010's Avatar
Andrew010
Bad fuel
Plugged fuel filters
Plugged air filter
Low tire pressure
Altered/removed front air dam
Not to mention lift kits and larger/heavier tires, if your truck has them.
To give any accurate answers we need ALOT more info.
Old Jul 8, 2012 | 06:44 PM
ken1960's Avatar
ken1960
it has 20 inch tires an wheels and it has 23000miles on it an is a 2011 model , i have changed the fuel filters
Old Jul 8, 2012 | 07:54 PM
cleskybear's Avatar
cleskybear
In the "for what it's worth" pile, my MPG was stuck between 12-14 for the first year. I also had an annoying off/on squeak from the front wheels. Long story short, my 5th visit to the dealership revealed that my front calipers were hanging and they replaced most of my front braking system....my MPG went up to 18-19 overnight. I just took a 1500 mile trip which included several hundred miles of the Blue Ridge Pkwy and averaged 19.8.
Old Jul 8, 2012 | 07:59 PM
cirrus365's Avatar
cirrus365
Hi Ken. Have you talked to your dealer about this? You should be in the 16-19 mpg range on summer fuel. (IMO)
Old Jul 8, 2012 | 08:30 PM
ken1960's Avatar
ken1960
yea i took it to the dealer other day an he done the recall ,an said also it was stuck in the regen cycle but it has not gt any better.
Old Jul 8, 2012 | 08:47 PM
2addy's Avatar
2addy
Being stuck in regen will definitely destroy your fuel mileage. I agree with cirrus365; you should be getting much better mpg than what you are (with my 355 rear end, I get close to 19mpg overall). Is your odometer accurate? Mine was off 13 percent. Also, are you hand calculating versus relying on the computer? Mine is off but only by about .3mpg. All of these things can add up.
Old Jul 8, 2012 | 08:53 PM
ken1960's Avatar
ken1960
the last tank i gt 270 miles to tank23 gallon if you caclulate it 11.7 mpg , if i drive it real esay i can gt 13 by the conputer
Old Jul 9, 2012 | 04:53 AM
Gunny77's Avatar
Gunny77
Try using a cetane booster, you may have crappy fuel in your part of the world.
Old Jul 9, 2012 | 08:28 AM
ruschejj's Avatar
ruschejj
Are your front hubs engaged? Confirm they're in the "auto" position.
Lift the truck and spin the wheels, make sure they are free.
Tires need to be 70psi.
Treat the fuel.
Reset the mpg and trip odometers, try again.
I get the mpg you describe when it's really windy, hilly, or driving a lot of stop and go. Mpg also gets very low when you idle for ten minutes. Any time you are running the engine and not moving the info on the screen will read lower mpg. Frequently this is a forgotten thing.
Sounds like you have a calibration issue, sensors are feeding info that makes your engine run too rich.
Old Jul 9, 2012 | 10:29 AM
lundman's Avatar
lundman
poor fuel mileage
Something sounds wrong with that kind mileage reading. I have had my 2011 F-250 Lariat Diesel FX-4 since December 2010 and have never got crummy mileage like that? Not towing I usually get about 11.4 litres per 100 and even city driving it might get to just over 12.3 litres per 100. That equals 19 to 21 miles per gallon American. Might get slightly less if the air conditioner is on but not near what you seem to be getting. My 6.7 beats my 6.0 litre Chev gasser I had previously by a lot. You need to get the dealer to figure out why the mileage is so poor? Gas is going up and don't need to empty your wallet filling it up. I can get over 800 kms on a full tank of diesel not towing. That equals to 500 plus miles on a tank of gas. I always to my best to keep it near full though.
I have the club cab short box....6.5 feet.
Get er fixed. What would be the mileage if you were towing? Definitely something is a miss.
Old Jul 9, 2012 | 08:04 PM
CornTruckDriver's Avatar
CornTruckDriver
Originally Posted by ken1960
it has 20 inch tires an wheels and it has Miles on it an is a 2011 model , i have changed the fuel filters
331 gears with 20 inch wheels, are you modified?
