You've posted this in the 2009+ forum, but you might get a bit more help in the 87-96 forum. Maybe our moderator Tim can move your post there. In the meantime, what engine do you have? What is your timing set at? If a 95 do you have a speed density or mass air setup? And do you have any known vacuum leaks?
