AC issues on 2004 Excursion
Old Jul 7, 2012 | 06:52 PM
bonedoctor's Avatar
bonedoctor
Hello there,
I'm recently the proud owner on a 2004 Ford Excursion Eddie Bauer with 85,000 miles on it. It is a 4x4, V-10 equipped truck with 3.73 rears. We bought it approximately 2 months ago and have not used it much to date. It needs tires and before I replace them I going to put a 5" superlift lift on it and then 35" tires. I'll get some pics up real soon.
My problem is that we took the X out today and went to use the AC and....nothing. My first thought was low Freon but then I noticed that the clutch was not engaging. I tried to spin the clutch and...nothing....can't even get it to budge. So my question is...what next? Does it mean the compressor is shot...or just the clutch?
Any suggestions? I read abouty jumping the switch but I'm afraid of it trying to engage a frozen clutch and then not disengaging.
Thanks
Old Jul 7, 2012 | 09:15 PM
HD RULES's Avatar
HD RULES
Low pressure switch may be preventing clutch from spinning. Real way to know is to get some gauges on it.
Old Jul 7, 2012 | 09:20 PM
wpnaes's Avatar
wpnaes
https://www.ford-trucks.com/forums/1...-warm-air.html
http://www.springerpop.net/F350/air_gap.html
Old Jul 7, 2012 | 10:06 PM
Sader's Avatar
Sader
Hmm, you grabbed the clutch and nothing moved at all? I just stepped into the garage, I can turn the clutch on mine. Almost sounds like the compressor is seized. Although I had one seize in the past and the clutch would still engage, sounded horrible with the grinding metal.
Sounds like a mechanic diagnostic is in the works, there could be other things causing your symptoms.
Good Luck!
gtadim
Jul 6, 2019 06:06 PM
James.
Apr 27, 2014 07:18 PM
Billy Brethren
Jun 16, 2011 11:56 AM
rudyexp
26
Oct 17, 2007 08:10 AM
ford351c
Jul 4, 2006 12:54 PM
