Aerostar Ford Aerostar
A/C Comp. not working
Old May 8, 2003 | 11:52 PM
willmiller's Avatar
willmiller
Question A/C Comp. not working
1992 Aerostar 4.0L
The compressor will not come on with the A/C switch but worked fine when I connected a jumper wire to it. I wanted to know if the system has any pressure switches in it or anything else that might keep the compressor from operating. Also, where could I get a "good" wiring diagram that could help me track down this problem. Thanks in advance for pointing me in the right direction.
Thanks,
Will
p.s. I really like this site.
Old May 9, 2003 | 09:40 AM
aerocolorado's Avatar
aerocolorado
Yes, there is a low pressure switch on the accumulator, the cylindrical looking affair on the firewall between the blower motor and fender. Disconnect the two wire connector at the accumulator and jumper across that. If the compressor operates then either the low pressure switch is bad or the system is low on refrigerant and needs recharged.
Old May 9, 2003 | 12:45 PM
willmiller's Avatar
willmiller
Talking A/C Comp. not working
Thank you very much. Thats just the kind of answer that I needed to help in my troubleshooting. I will try that over the weekend at let you know soon.
Thanks again,
Will
Old May 12, 2003 | 06:39 AM
willmiller's Avatar
willmiller
The low pressure switch was the problem. Thanks for the help.
Will
Old May 12, 2003 | 12:47 PM
aerocolorado
Thank you Will, for following up. Knowing the outcome helps all of us to help each other.
cjdmcgarry
Aug 19, 2014 10:12 AM
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
dave44434
Aug 22, 2011 06:30 PM
colonelsanders2k7
May 31, 2011 11:38 PM
jeff gammon
Aug 4, 2009 11:56 PM
