Please help....2007 Expedition will not start
Old Jul 7, 2012 | 03:44 PM
osbornemk's Avatar
osbornemk
Hello, my 07 Expedition will not start, starter works fine. It started about 2 weeks ago while on vacation....I got in the car, turned the key and it turned over about 4 times before starting. Never had a issue before It always started the first time. I got home, drove it everyday to work....no issues. Yesterday I got in it to go to work and it took 5 ot 6 times of turning the key before it cranked up...so on the way home from work I picked up a new fuel filter. When I pulled the old one off I blew in it and it was hard compared to the new one.....so I thought good problem solved. It started like new and I drove it to a buddies house. When I got back in to come home it would never start again....it turned over just fine but would not crank. Isnt there some kind of reset for fuel pump? Is the fuel pump bad?? Thanks for any help on this matter.
Old Jul 7, 2012 | 04:09 PM
lv2race's Avatar
lv2race
Disconnect the negative cable on the battery for a minute, then put it back on and try it again.
Old Jul 7, 2012 | 09:10 PM
alloro's Avatar
alloro
To me it sounds like your fuel pump is shot. You need to buy or rent a fuel pressure gauge to test if the pressure is up to specifications.
Blaggie1216
May 4, 2018 05:59 PM
nyjetfan
Sep 30, 2016 10:10 PM
PrivateIdaho
Dec 14, 2009 10:27 PM
H2Oskier313
17
Oct 11, 2005 02:59 PM
