Sponsored by: Real Truck
Door Code
Old Jul 7, 2012 | 03:37 PM
Ridenred333's Avatar
Ridenred333
Door Code
I have an 04 f250 bought used. I dont know the keyless entry code. Any way to find out what it is or how to reset it? Thanks
Old Jul 7, 2012 | 03:41 PM
Indyducks's Avatar
Indyducks
I had to take my ford five hundred to the dealer. Took 5 minutes to plug it in and read the code. My guy did it for free. I figure it would be the same on a truck of the same age.
Old Jul 7, 2012 | 03:47 PM
Ridenred333
ok thanks I will call them.
Old Jul 7, 2012 | 06:30 PM
projectSHO89's Avatar
projectSHO89
It's probably printed on a label on a module under the dash.
Old Jul 7, 2012 | 07:14 PM
mikeismadness's Avatar
mikeismadness
It is under the dash. I'm pretty positive u have to remove the radio
Old Jul 7, 2012 | 07:47 PM
Ridenred333
i will check into that. thanks
Old Jul 7, 2012 | 07:49 PM
almostgone's Avatar
almostgone
Door code for 2008 F250 CC Lariat
Thanks to some posters back in April, I found my code. It was behind the passenger side kick panel and BEHIND the fuse panel that you will find there. You have to remove the kick panel, step panel (says Super Duty on it) and the trim on the front of the door. Once you have removed that, take the two 7mm screws holding the fuse panel. You will find two labels on the back.
Look to the lower left of the label in the center of the fuse panel for a very small five digit number. THATS IT!!! You just saved yourself some money.
Old Jul 7, 2012 | 08:29 PM
Ridenred333
I will try this first sounds like less work, maybe LOL. Then removing the radio. Then if I dont find it I will remove radio. I appreciate everyones imput on this. I have it on my explorer and us it all the time. I usually leave keys in the truck and us code to get in especially when I go to pt in the morning. Those in the military know what I am talking about. There is know where to put your keys with our pt uniforms.
Old Jul 7, 2012 | 08:31 PM
Ridenred333
This is on the drivers side correct?
Old Jul 7, 2012 | 08:34 PM
Ridenred333
nevermind I just relized your said passenger side. I am an idiot sometimes.
Old Jul 7, 2012 | 09:03 PM
almostgone's Avatar
almostgone
Door code
You have an '04, so chances are its not going to be where I described. My owner's manual said that its printed on the computer module.... never found it. Found it on a fuse panel... A..holes!!! Found it thanks to doing search on this site for my specific stuff. Do a search on this site for your specific year etc... That's how I found mine.
Old Jul 7, 2012 | 09:22 PM
mikeismadness
We found the code behind the radio on an 06 6.0 PSD. If that helps
Old Jul 7, 2012 | 09:28 PM
Ridenred333
I have the 04 also.
BGilley
2009 - 2014 F150
Jul 14, 2009 08:17 PM
kystangbanger
Apr 14, 2009 06:18 AM
generalee31184
Feb 1, 2009 03:31 PM
waterpourer
2004 - 2008 F150
Oct 30, 2007 09:42 AM
greygoat69
1997 - 2003 F150
Jul 19, 2003 08:53 AM
