PCM fried?
Old Jul 7, 2012 | 12:16 AM
bbeck45's Avatar
bbeck45
PCM fried?
I was putting my chip back I'm tonight after not having it installed for a year or so. I didn't bother to look at the install instructions prior and in a moment of sheer brilliance I pulled the chip out while the ignition was on. Now the truck will only turn over but won't start. I have checked the fuses and they are all good. I have also swapped relays around but no joy. Am I really as screwed as I think and need a new PCM or is there something else I can try? If so where can I get one without going to the dealer? Thanks in advance for any help.
Old Jul 7, 2012 | 12:25 AM
GonzoCSU's Avatar
GonzoCSU
What kind of chip? Did you look at the circuit board to see if you can visibly see anything fried?
Old Jul 7, 2012 | 12:37 AM
bbeck45's Avatar
bbeck45
It is a DP chip, I pulled the PCM apart and it looked ok, no burnt smell or black spots.
Old Jul 7, 2012 | 12:46 AM
bbeck45's Avatar
bbeck45
Also I have tried to plus in a bulldog programmer to pull the codes but it can't connect and I do not hear the fuel pump kicking on when I turn the key.
Old Jul 7, 2012 | 08:11 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Give Jody a call and he will tell you what you need to do. He can reflash the PCM if you didn't burn it up, which I think you did.
Old Jul 7, 2012 | 08:33 AM
bbeck45's Avatar
bbeck45
Is the PCM a dealer only part?
Old Jul 7, 2012 | 10:44 AM
GonzoCSU's Avatar
GonzoCSU
I agree, call Jody he will be your best source of knowledge on the PCM. I think Autozone can actually get PCMs but I wouldn't make a move yet until you talk to Jody about it it will have a better idea of what happens when you remove the chip with the power applied and he might have a good source for the PCM.
Old Jul 7, 2012 | 03:09 PM
bbeck45's Avatar
bbeck45
Yeah, I shot him an e-mail last night and was planning on giving him a call Monday morning.
Old Jul 7, 2012 | 03:40 PM
bcaughhorn's Avatar
bcaughhorn
Does your cigerette lighter plug have pwr? If not its on the same fuse as the pcm.
Old Jul 7, 2012 | 07:41 PM
bbeck45's Avatar
bbeck45
BC, yeah the lighter works. I actually went through every fuse last night in an act of desperation.
Old Jul 7, 2012 | 07:50 PM
sand_fiend's Avatar
sand_fiend
Is the chip pluged in the right way ?? a DP chip will go in both ways but only one is right..
did you plug the main plug back in to the back ?
Old Jul 7, 2012 | 10:55 PM
Bonanza35's Avatar
Bonanza35
You most likely burned out the PCM. Jody use to sell them as well. Talk to him monday. Good luck and let us know.
Chet
Old Jul 8, 2012 | 09:11 AM
megawatt00's Avatar
megawatt00
Like all have said You have fried your PCM. The most important step in removing the PCM whether installing a chip or not is to make sure than your keys are not in the ignition.
When the keys are in the ignition, they "wake up" the PCM this wake up allows voltage to go into the PCM , Removing it while voltage is present is usually catastrophic for the PCM.
Old Jul 8, 2012 | 09:30 AM
shorebird's Avatar
shorebird
<iframe width="640" height="480" src="http://www.youtube.com/embed/8ozdu4CqOAI" frameborder="0" allowfullscreen></iframe>
Time to get another PCM.
Old Jul 8, 2012 | 12:40 PM
PaysonPSD's Avatar
PaysonPSD
I got 2 PCMs by going through car-parts.com.
After choosing year and model click on Engine Computer.
They are listed by part number and not PCM type.
You can find part number info at this LINK.
I paid less than 100 bucks each for 2 PMT1s.
