'48-52 gas tank valve
Old 12-13-2016, 10:46 AM
EAK69's Avatar
EAK69
EAK69 is offline
When I said it doesn't turn, I should have said it isn't stuck, there is a piece broken and needs to be replaced!!
Old 12-13-2016, 11:36 AM
firstrider's Avatar
firstrider
firstrider is offline
Both '52's in the stable have the gas shut off valve . Glad they do . Very handy item .
Old 12-19-2016, 10:01 PM
51fred's Avatar
51fred
51fred is offline
Just replaced my fuel pump and when I opened the shutoff valve it started leaking. I looked up the part #7HC-9189 on Backcounter.com. Dennis Carpenter NOS parts had a couple. It just arrived today and is the same as in the first picture. $20 + shipping. Now to replace it with 3/4 tank of gas......
Old 12-20-2016, 02:02 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
Old 12-20-2016, 09:56 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Originally Posted by 51fred
...Now to replace it with 3/4 tank of gas......
Fuel pumps and fuel lines always go bad when you've just filled the tank!
Old 12-20-2016, 03:08 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Applications: 1948/52 all trucks.
MUSTANG'S ETC. in Van Nuys CA has 1 = 818-787-7634.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
OBSOLETE RELIABLE PARTS in Nashville GA has 5 = 229-686-5101.
Old 12-20-2016, 06:52 PM
roadrunner01's Avatar
roadrunner01
roadrunner01 is offline
My local hardware store has the valves in the bin, I chose not to put one in. I elected to go with a 90 out of the tank to 3/8" push lock hose up to the fuel pump.
I have a tank full of rust/debris so I installed a racor filter before the fuel pump. so far so good as I have caught ALOT of junk and kept it out of the fuel pump. I know eventually I may have to replace the tank, but I was able to put about 1,000 mi. on the '49 last summer/fall.
tinman52
15
07-27-2017 03:50 PM
Ole Reliable
17
07-05-2013 06:19 AM
Rovernut
35
04-01-2013 07:41 AM
otisdriftwood
01-05-2013 08:31 AM
Big block bronco
10-11-2008 02:47 PM
Quick Reply: '48-52 gas tank valve
