View Poll Results: reasons it could be
cps
50.00%
fuel pump
50.00%
computer
0%
Voters: 2. You may not vote on this poll
won't start
Old May 8, 2003 | 09:56 PM
scarF250's Avatar
scarF250
won't start
i got a 97 f-250 psd and it quits running and i just replaced the camshaft position sensor and it ran fine for a day and today it just cranks over but won't start. just wondering if it could be a bad sensor or something else.
Old May 9, 2003 | 01:39 AM
The Diesel Dude's Avatar
The Diesel Dude
won't start
You need 5 things to run this engine: 1) air; 2) compression; 3) high pressure oil; 4) fuel; 5) proper signal from the computers to run the injectors.
Unless you've got the tools and expertise to do the diagnostics, you may be well off to take it to Ford or a Power Stroke tech. There is a schrader valve on the fuel filter header that you can access to read fuel pressure and if you've got a DVOM and an ICP break-out you can read H/P oil rail pressure. If not just unplug the ICP and try to start it. If it starts, your ICP is no good. If it doesn't, find a mechanic with Power Stroke experience.
Old May 20, 2003 | 03:59 PM
The Grinch's Avatar
The Grinch
won't start
As I was asked when I had a similar problem, do you have rpm indications when turning over the motor? If not, check your fuses under the hood.
