Sponsored by: Auxito
Ford PATS Hell
Old Aug 19, 2012 | 02:25 PM
  #31
jhuggs82's Avatar
jhuggs82
Yes I was trying to get help here but guess the fact I don't have a F150 I would be silly to find some outside help from someone that might have the info I'm searching for.... Similar vehicle components and similiar problem so figured it would be a good start.... Ill move on to the Excursions as you suggested...
Old Aug 19, 2012 | 02:27 PM
  #32
Lead Head's Avatar
Lead Head
It's because your Excursion PATS system is very different, with a different ECU, electronics, completely different engine, etc..
The people down in the Excursion section a few page-scrolls down would definitely be more knowledgeable.
Old Aug 19, 2012 | 07:26 PM
  #33
projectSHO89's Avatar
projectSHO89
Excursion and Super Duty trucks are pretty much the same. 1/2 ton pickups are completely different. Having a diesel makes it even more important you ask i the "best" section.
Old Aug 25, 2012 | 06:24 PM
  #34
DetroitDiesel's Avatar
DetroitDiesel
Could use some insight on PATS...
I have a 1998 Expedition, 4.6l, just did a motor swap with a crate motor from a 1992 Crown Vic... Both Romeo motors, everything bolted up just fine. Added headers and all new everything to the motor...injectors, components, etc. All goes well until I turn her over for the first time and I get the evil PATS fast blinking issue. Check connections, all seem ok. Connect the Snap On Red Brick scanner, and it can not communicate with the ECM. check the relays, etc, does not appear to have any issues there.
Truck was running fine with the original 4.6l with 307,000 on it before a little piece of carbon roached that motor. No issues before then.
Any ideas, recommendations, etc?
ANy and all would be appreciated
PK
Old Aug 26, 2012 | 07:11 AM
  #35
projectSHO89
Probably a PCM power problem...
Old Aug 26, 2012 | 12:32 PM
  #36
jhuggs82's Avatar
jhuggs82
Is the theft light blinking fast? Did it do similar to what mine did?
Old Jun 12, 2013 | 12:16 AM
  #37
Eric_in_oklahoma's Avatar
Eric_in_oklahoma
1 Year Later
Just a followup on my original post here. It has been a year now since I disconnected the alarm taps under the dash.
No problems starting the truck since then. Problem solved.
It was not a PATS issue, but an alarm problem.
Thanks for all the input.
brian42
Dec 12, 2016 02:50 PM
Tonyplane
6.2L V8
Jul 2, 2014 07:26 AM
cardc26
Sep 18, 2012 05:04 PM
darkwingduck
Oct 26, 2005 11:22 AM
shanaschuyler
Electrical Systems/Wiring
Sep 6, 2003 05:04 AM
