Passenger airbag light On
I've had my 2004 F150 for almost 2 years now. For almost the last year my airbag light has been on. No codes, just the airbag light on the dash being on and occasionally the light on the console turns on.
Are there sensors that may go bad? I've looked and everything under the passenger seat is connected. I searched the forums but couldn't find anything.
Going to be upgrading the truck soon, just need to take care of all the little things first.
Thanks!
Thanks!
Usually air bag lights only come on because of a sensor needing replacement as you mentioned. I know there are expensive machines that hook up to the OBDII port and tell you exactly which one.
You might try taking it somewhere to see if you can get a free diagnostic. They shouldn't charge you anything unless they do the work if they're a good shop/company.
Hope this helps!
Hope this helps!
