I put up another thread about this but I have not gotten any response yet so I will try here. Does anyone know where I can get the tan plugs for the headliner? I am missing 4 for some reason and I am having a hard time matching to a google search.
Found these, but they are for 2003-on. Not sure if the post diameter is different or not. Color won't matter because you can replace them all.
When we camp or travel it is usually in a group so I had to have a CB. I wanted a nice compact unit so I decided to give the Cobra 19 a try. Matched it up with a Little Wil
Hard to see the antenna but I like the looks of it.
Reason: more text
You may also want to remove your roof rack crossbars. They tend to rub on the roof causing paint wear and/or rust. If you don't use them then you may want to pull them off.
Keep up the good work!
Where do they rub ? The only paint wear I see is on the bars themselves.
