So, here's my problem. I have a 1996 ford f350 5.8 liter that doesn't have any spark, but is getting fuel injection. I've checked the ICM, replaced the coil, and distributor cap. I'm getting proper voltage, good ground to ICM, and I was getting a signal from the PIP sensor. The pip signal started off week and then slowly got stronger while cranking though. So, I read that if you disconnect the computer you should get spark if the PIP sensor is bad. I did this and I got one single spark every time I started cranking, but never again after that. Any ideas? I also wanted to try disconnecting the SPOUT sensor, but I have no idea what this is and where it is. The truck also seemed to have a bad ground before the no spark issue occurred. The truck was running really rich before this and showed a bunch of codes for high voltage on a lot of the sensors, but I think this a completely separate issue. I'd appreciate any suggestions thanks.
You either misread something or the interwebs rumor is wrong. If you have a bad computer (PCM) you can disconnect it to see if you have spark.
You stated you have "fuel injection", I interpret that to mean you are getting injector pulses? A bad ground can wreak all kinds of havoc. What did you do to resolve the original ground issue?
When troubleshooting ignition problems I like to refer to these articles:
I never could find the bad ground, but I'm not sure I checked and cleaned all of them. Does anyone have list of where all the grounds for the engine wiring hanress are? Expecially the ground for the map, tps, and egr sensors, which came up in the original codes from the engine.
All of those sensors are referenced to Signal-Return, Pin 46 of the PCM (Engine Computer). The PCM is grounded through the body ground G101, located next to the battery and starter relay. The other ground that many overlook is G100 located near the driver side headlight on the radiator support.
Ok, grounds were all cleaned. So, I got spark back after disconnecting the spout signal. I also checked the spout signal, ac voltage, while cranking and I didn't get anything, which means a bad pcu. Correct? So, I should be able to get the truck to run by disconnecting the spout connection, but now it doesn't seem to be injecting properly. I checked injection a few days ago and I was getting 3 volts constant voltage to the injectors that seems kind of low to me.
By disconnecting the SPOUT plug you are removing the PCM from controlling the ignition circuit (spark). The only items in the ignition path are now PIP (stator) inside the distributor and the Ignition Control Module. If you would use the links in my previous post you would be able to narrow down the root cause.
If you have only 3 volts on the supply side of the injectors you have a completely separate issue. You should have battery voltage (+12 VDC nominal) on the supply side. It's the PIP signal that triggers the PCM to ground the other side of the injectors. This will cause the injector(s) to open to allow fuel flow.
Some handy diagrams to reference:
Basic Ignition
Basic Injector diagram:
EEC relay and Fuel Pump, relay (listed for a 5.8L engine but very similar to your 7.5L)
