Sponsored by: Innova
memory on the radio
Old May 8, 2003 | 08:05 PM
diesel demond's Avatar
diesel demond
memory on the radio
i finaly got my radio installed and it works great!!! the only problem with it is that it doesn't save my presets, or time settings. what can i do to correct this?
Old May 8, 2003 | 08:08 PM
optikal illushun's Avatar
optikal illushun
memory on the radio
u need to run a constant power wire for the memory, usually to the battery with an inline fuse.
Old May 8, 2003 | 11:11 PM
diesel demond
memory on the radio
you dont think that maybe i just got the ignition and constant mixed up?
Old May 8, 2003 | 11:13 PM
optikal illushun
memory on the radio
could be...i didnt know if u used a harness or not.
Old May 9, 2003 | 08:43 AM
PrPlayboy's Avatar
PrPlayboy
memory on the radio
If all you did was replace the radio than thats probly what happened. They are mixed.
Old May 9, 2003 | 11:57 AM
carlos694x4's Avatar
carlos694x4
memory on the radio
The ignition power wire should be yellow with a black stripe, and the constant should be green with a yellow stripe if i am correct.
Old May 9, 2003 | 04:56 PM
diesel demond
memory on the radio
ya i did them opposite... constant to yellow/black, and ignition to green/yellow. so all i need to do is switch them than right?
