Master cylinder
Old Jul 4, 2012 | 08:29 AM
reg1952's Avatar
reg1952
Master cylinder
Have got my brakes ready to bleed last night. Had a proplem getting fluid to flow.Took master back off and found plundger in master not returning.Took master apart and everything is good.The only thing I can think of is the seals have swellled from setting 3 years.Its a corvette style from Hortons hot rods.Called them and they have no rebuild kits.Any one know about what year I could order a kit for?
Old Jul 5, 2012 | 10:10 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51
Dont know really without a picture of it and guessing but what seems to be the norm are the ones pictured below in which case around '68-69. Best guess estamate. Hope this helps you in the right direction.
Old Jul 6, 2012 | 12:45 PM
teardropty's Avatar
teardropty
Probably 70s to 80's GM kit. I would hesitate rebuilding a master cylinder unless you have done it before. Of course I have a brand new MBM master cylinder Corvette Style GM for sale at $80. You could also have a bad casting/tapping in the master cylinder preventing flow.
Old Jul 6, 2012 | 03:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The seals may have just taken a set while sitting. Once they get some pressure and wear on them they may be OK. Try bench bleeding the M/C, then installing and bleeding the whole system. Nothing to lose but a few bucks worth of fluid.
Old Jul 6, 2012 | 03:25 PM
reg1952's Avatar
reg1952
Got a new one today for $69.Had to switch lines around because the first one had ports on both sides.Bleed it out with no proplem.Ordered one for a 75 vette.
Joe Kelly
Large Truck
Aug 28, 2018 01:37 PM
azfordf100man
15
Sep 23, 2007 08:00 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
kameronth
1978 - 1996 Big Bronco
Aug 26, 2004 09:01 PM
