Tach reads backwards??
Old May 8, 2003 | 07:49 PM
78bigunns's Avatar
78bigunns
Question Tach reads backwards??
Guys, coming back from the landfill tonight, noticed my tach was starting out below 8g on idle, then slowly working it's way backwards to about 6500 or so at 50 mph. Seems like it would be about right if it was at 0 then went up to 1500 at 50 mph when normal. I just noticed this, don't know how long it's been like this, what could be the culprit?? It's dark now, I'll have to glance at the wiring in the morning. Thanks and later, Blair
Old May 8, 2003 | 08:08 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Blair, the polarity has somehow reversed. I would suspect maybe the wiring plug into the tach, or a fault in the tach itself.
I gave mine a good spray of WD-40 last year, when it started registering 1/2 rpm. That worked for me.
Old May 8, 2003 | 08:12 PM
78bigunns's Avatar
78bigunns
Thanks, I'll be checking tomorrow. Later.
Old May 8, 2003 | 11:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad connections can cause this also.
Old May 9, 2003 | 10:44 AM
beartracks's Avatar
beartracks
bad connection, coil or ignition box going bad.
Old May 10, 2003 | 11:05 PM
saintthomas's Avatar
saintthomas
Every time that I have seen this it has been the tach itself.
Old May 11, 2003 | 09:16 AM
78bigunns's Avatar
78bigunns
Thanks for the replys, I'll check it out today now that it's not raining. Later, Blair
andym
21
Apr 16, 2020 03:51 PM
81Bronk36
21
Apr 11, 2017 03:17 PM
carsronnie86
May 24, 2016 04:22 PM
Ikes_Fseries
Jul 5, 2012 08:36 AM
LCPullman
17
Jan 11, 2010 01:34 PM
