1978 - 1996 Big Bronco
Tire Pressure
Old May 8, 2003 | 05:14 PM
buckeyebronco's Avatar
buckeyebronco
Tire Pressure
my 90 Bronco says on the door post that I should have 35 psi cold in the front and 41psi cold in the back. yet my front tires look too low and have about three inches of contact front to back. should I have both of them at 41? Also what is considered "cold".
Old May 8, 2003 | 09:18 PM
steve83's Avatar
steve83
Tire Pressure
"Cold" is after it's been sitting for a while - not immediately after driving on the highway for an hour.
Those are the factory recommended pressures for the OE tires to give a comfortable ride. You have to adjust the pressure for your own use & especially for replacement tires. I carry so much crap all the time that I run 45psi F&R for a smooth ride & even wear, and max out (50) when I tow or haul.
You should check the treadwear to get the right pressure. The Haynes manual has pictures to help.
stydel311
May 4, 2014 11:48 AM
kx450frider617
Dec 29, 2013 08:41 AM
DoofusOfTheDay
Oct 22, 2013 05:31 PM
hypophthalmus
19
Jul 1, 2012 07:53 PM
fjlee
Nov 27, 2007 05:11 PM
