HIGH HC, FAILED SMOG?
Old Jun 30, 2012 | 03:49 PM
F150-AMERICA's Avatar
F150-AMERICA
I failed smog with high HC on my 92 Ford F150? What could be the cause, how can I check? Tips?
Old Jun 30, 2012 | 08:07 PM
Ed Bamba's Avatar
Ed Bamba
Have you performed KOEO and KOER self tests yet? When my truck failed smog, it had a code come up for the Thermactor system, but that doesn't mean yours will be the same. Do the test and post what you find.
Old Jun 30, 2012 | 08:32 PM
Bankrupter's Avatar
Bankrupter
what year is your ford? most are smog exempt at this point.
Old Jun 30, 2012 | 10:25 PM
F150-AMERICA
Don't really know what those tests are? I put new spark plugs in, air filter, and soon to be new thermostat which should help cause my coolant gauge just hovered over the normal line on the cold side (about 1/8). Don't those tests tell you why check engine light is on? How can I check if CAT is bad?
Old Jun 30, 2012 | 11:35 PM
Ed Bamba's Avatar
Ed Bamba
Sorry about that. KOEO stands for Key On Engine Off, and KOER stands for Key On Engine Running. Here is a link from this site that will get you started, https://www.ford-trucks.com/forums/1...an-eec-iv.html
Old Jul 1, 2012 | 03:28 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If the truck isn't warming up (or doesn't think it is) the computer will always have it running rich.
Fuel Injection Technical Library » How To Run a Self-Test
Fuel Injection Technical Library » 2 Digit Self-test Codes 11-32
Fuel Injection Technical Library » 3 Digit Self-test Codes 111-171
http://oldfuelinjection.com/files/self_test.pdf
Go to a big chain auto parts store and have them pull the codes if you can't figure it out.
Old Jul 1, 2012 | 10:26 AM
oleman's Avatar
oleman
Federal smog testing goes back for 25 years in some areas.
Our old F350 gasser still has to be tested in this North DALLAS Texas area.
Worn out engines will not pass smog and there is NO computer code for compression or other engine vitals.
If it is an oil hog or in general BAD, it will have to be repaired to pass.
It's old, leaking fuel injectors and other mechanical problems will take their toll over time.
Old Jul 1, 2012 | 10:31 AM
Lead Head's Avatar
Lead Head
It's 25 years old before you're exempt down here in RI.
As mentioned, start by checking the codes.
High HC is caused by running too rich. Common problems that can cause this:
Bad Engine Coolant Temperature sensor
Slow/Bad Oxygen Sensor
Failing Catalytic Converter
High Fuel Pressure
Non-functional A.I.R/Thermactor system.
Old Jul 1, 2012 | 12:45 PM
Bankrupter's Avatar
Bankrupter
High Fuel Pressure
My 95 is good here in MA.. sorry all.. Wont the 2 bottles of injector cleaner trick work to get the sniffer past the HC's?
Old Jul 1, 2012 | 01:03 PM
85e150's Avatar
85e150
OP is in CA, has a '92 F150.
To OP: What engine and transmission? EFI, right? Any mods?
Were you able to fix the fuel cap?
High HC is high hydrocarbons, which is almost always a too-rich mixture. If your engine is stuck in a "cold" mode, that would do it.
As to your cat, your CO number are a bit high, but you pass. I would say your CO is high because your HC is high, causing your cat to have to work a bit harder in burning those up, at least in part. In short, your cat is good, focus on the mixture.
As per prior posts, is it an oil burner, do you have the air inject system--if so, is it working right and not clogged? Codes? You gotta figure that out.
IF this is all a mystery, find a shop to do the work.
CA requires the vehicle to be OEM, and tests back to '76. Quick fixes might be in order to get the cert, but he needs to make sure this gets fixed right or he will kill the cat and not be able to pass again in 2 years without an expensive replacement.
Old Jul 1, 2012 | 02:13 PM
Ed Bamba's Avatar
Ed Bamba
I was going to ask how you knew what his test results were. Then I noticed that there is an image, or link, to it that only shows up as a ? on my screen.
OP, as a quick check, inspect all your vacuum hoses/tubings, especially to the smog components. I believe that your smog components have vacuum ports like my 91 does. I replaced all my vac tubing with rubber hoses.
Jul 26, 2005 10:02 PM
'961506
General Automotive Discussion
Feb 20, 2005 10:19 PM
D Harry
Mar 18, 2004 08:24 PM
cmoore99
Jan 8, 2004 04:36 PM
rwsam
1978 - 1996 Big Bronco
Jan 6, 2003 11:59 PM
