Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How To Install a Suspension Block
Step by step instructions for do-it-yourself repairs
Lowering my 78' F150 and Crown Vic suspension swap
#77
Got some wheel adapters today to space the high offset rims out a bit as well as adapt from 5x5.5" to 5x4.5". The just kept on plugging away at boxing the frame and got the rear a-arm bushings mounted. I will most likely build a cross member between the two bushings once I figure out where the motor is going to sit.
Still a few more welds to make on the frame but it's coming along. Just had to quite since it's like 2am. I was falling asleep in the shop.
#78
#81
Damn that does make it easy! I'm guessing with the shackle/hanger drop in the back it will have a pretty steep rake to it? If the CV IFS does drop it 5", it's been my experience that shackles only drop the rear 1". I'd be real surprised if you get 3" out of shackles and hangers, even though they claim 4". Didn't see if you measured it, but I'd appreciate how much the rear actually dropped for some decisions of my own.
Edit- actually I think I found it in the first post - only dropped the rear two inches?
#82
#83
If you're cool with an 8.8 i suppose you could pull the whole rear, but I'm not sure what the width comes out to.
#84
#85
I put the entire 95 Explorer 8.8 in mine, has trac loc with 3.73's, disc brakes and sway bar and since I was flipping the axle anyhow I thought I might as well swap out the factory rear. But it is narrower, with my 17x10.5 wheels I still added two inch wheel spacers to each side.
#89
Here is my bump with the swap
#90
Mainly wanting to see how low his comes out compared to where mine sits now. Ideally I only want to drop the front 2-3 inches. I know I could build the subframe spacers on the bottom of the frame instead of the top. I also worry about the highly positive offset wheels being "sucked in" to the fenderwells too much. A lot of the pics I see look that way. I guess I could always run spacers. If the OP could take some pics like my "New truck" thread that would be just awesome. I haven't seen really good all-around pics of a dentside with the CV swap like that yet. I don't want my truck to look like a "lowrider" and I also have a steep-*** driveway approach at my house.
