Machined Wheel Help
Old Jun 30, 2012 | 08:53 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Machined Wheel Help
Ok so the place im staying lately has annoying sprinkers that seem to find my truck every morning no matter where i park. I find myself cleaning hard water spots daily as Ive seen vehicles ruined from hard water etching. They mostly come off painted surfaces but the machined face on my wheels is proving to be stubborn. Im fairly certain they are not clear coated as this would not be happening...
Old Jun 30, 2012 | 10:14 AM
Tomahawk's Avatar
Tomahawk
Lemon Pledge...
Old Jun 30, 2012 | 10:17 AM
Tuxedo Scorpion
that is exactly what i should have put on when new, now im stuck getting back to a clean slate. then for sure i will protect it with pledge or such.
anyone ever hear of gords aluminum polish?
Old Jun 30, 2012 | 10:38 AM
mrjc's Avatar
mrjc
Ive used mothers for polishing wheel and mom makes em shine, Windex for spots, never heard of Gords, maybe Gordon is Moms husand.
Old Jun 30, 2012 | 01:20 PM
Tuxedo Scorpion
picked up some mothers mag and aluminum polish.... works, but it usually takes a few applications and the spots dont just fall off like i was hoping. thus its a mother to use... guess thats why its called that.
Hard water spots are my new sworn enemy, right up there with corrosion. grrrrr
Old Jun 30, 2012 | 01:48 PM
Andrew010's Avatar
Andrew010
CLR maybe??
Old Jun 30, 2012 | 01:49 PM
Tuxedo Scorpion
maybe. just annoying to spend 5-10 dollars per product as a test. if i had the stuff around, i would experiment. but im back to living in hotels on the road lately... and dont have my full arsenal of tools/products at hand
Old Jun 30, 2012 | 02:16 PM
Hdslider's Avatar
Hdslider
I have tried alot of products. Some work easier than others, but I have found that most shine great but tarnish very quickly. So I stick with mothers, if can use a buffer, much simpler, then when I get it where I want it I spray a clear urethane over it. Then I'm done. You being on the road I wish you well.
Old Jun 30, 2012 | 07:06 PM
ruschejj's Avatar
ruschejj
Ok, clr is a good idea. Think further though, a bottle of vinegar is really cheap.
At the grocery, you've got vinegar, ammonia, bleach, oils, pledge, salt, toilet cleaner, comet, cascade, dryer sheets, borax, etc....
Seems like a shower tub cleaner or vinegar would be at the top of my list. Comet is pretty amazing too....then of course pledge.
Old Jun 30, 2012 | 07:27 PM
mhoefer's Avatar
mhoefer
Simonize heavy duty rim cleaner, then spray off and dry by hand. My rims went all winter and I scrubbed and scrubbed and tried polishes and hand applications and it still didn't look good. This stuff is expensive, but it cleaned them up so well I could not believe it. As in new rims from those who have survived their 6th winter in the north. With sand, salt, gravel, and yes, in places here they even use magnesium chloride in liquid form at times. I would stay away from CLR and other random chemical applications. My opinion, I am a chemist. After you have cleaned them, a coat of pledge to keep the dirty water off is a smart idea though really. The other product which would do the same is turtle wax ice. It can be used on all painted, chrome and plastic surfaces and doesn't leave white residue.
Old Jun 30, 2012 | 11:31 PM
Tuxedo Scorpion
i agree, and your experience completely validates my theory about protecting with pledge or such after back to neutral (i.e. no spots)
Old Jul 1, 2012 | 06:37 AM
dbc001's Avatar
dbc001
Heh Tux ..... Hope your enjoying your trip. The wheels are coated ...... Wait until you need a rebalance done and you can see the nice indents left by the weights in the coating. Sure ticks me off why they don't put the weights inside.
Old Jul 1, 2012 | 11:16 AM
mhoefer's Avatar
mhoefer
Have run Tux. I know what being on the road is like and focussing on the truck is a good way to keep outta trouble he he.
Old Jul 1, 2012 | 11:20 AM
Andrew010's Avatar
Andrew010
They put weights on the outside of an aftermarket wheel on your truck? Or the factory wheels?
Aftermarket wheels should always be static balanced.
Old Jul 1, 2012 | 11:54 AM
Tuxedo Scorpion
No weights on the outside. All inside and reinstalled/painted by me. Also the black part of the wheel is painted or powder coated and the machined part is not coated. I know because i polished some and the polish turned black as usual
