Speedometer problems and some wiring questions
Old Jun 29, 2012 | 11:05 PM
Links56's Avatar
Links56
Question Speedometer problems and some wiring questions
Hey guys, I have been a member on here for awhile but used to hang around the pre-powerstroke forums. Anyway, I recently acquired a 2003 f350 that has had a 12v cummins swap done to it. The owner before me removed the cab to install the engine. Ever since that the speedometer doesn't work, also the abs light is on. I have changed the rear end speed sensor and made sure the abs module had a good ground. I also have taken apart every connector I can find and reseated them. That's problem 1.
Problem 2 is I received the truck with a hacked up wiring harness where the last owner used only green colored wire to wire everything, There's wires cut everywhere and I'm not sure what some connectors are for, I have weeded out as many wires as I can that aren't needed. I would like to know what the AC clutch and high pressure switch connectors and wire colors are. Also there is a connector on the end of the brake master cylinder, I'm not sure what it is? The water in fuel light also, what does the connector look like and wire colors. I assume the water in fuel sensor from the cummins operates the same way as the Fords. Any help would be greatly appreciated. Thanks!
Old Jun 30, 2012 | 08:54 AM
cheezit's Avatar
cheezit
not trying to sound rude so please dont take it that way. I think your best bet might be to use alldata online for a few weeks so you can trace out exactly what it is your looking for.
Old Jun 30, 2012 | 09:14 AM
Fulthrotl's Avatar
Fulthrotl
+1... otherwise, sounds like "tell me what you see in the rear view
mirror, and i'll tell you which way to turn the wheel to parallell park".
alldata diy is $26.95 a year for one vehicle. time to load the money gun.
http://www.alldatadiy.com/buy/index.html
jjakef96
1983 - 2012 Ranger & B-Series
Nov 30, 2023 08:24 PM
lovemy150's
May 25, 2016 08:30 PM
merkswitch
Nov 16, 2015 08:40 AM
Krazee Matt
Jun 21, 2015 03:57 PM
KF4EYR
Apr 20, 2015 10:59 PM
