Need Translation
Old Jun 29, 2012 | 05:52 AM
tjustice's Avatar
tjustice
Need Translation
Short version.....Towing up mountains from Tn/NC, truck pulling best it has ever pulled, then just shutoff, never to restart. Had towed to dealer, this is what I got; Ran performance test found low ICP HP SYS building 38 PSI possible IPR stuck open.....So can anybody tell me what that means in simple form?
Thanks
Old Jun 29, 2012 | 05:59 AM
wulfman's Avatar
wulfman
tjustice this means you don't have enough oil pressure to fire the injectors . What year truck . Where in east TN are you ?
Old Jun 29, 2012 | 06:02 AM
tjustice's Avatar
tjustice
In between Johnson City and Bristol.....so looking at HPOP? Truck is disassembled for head gaskets and various other parts at the current moment.....
Old Jun 29, 2012 | 06:03 AM
tjustice's Avatar
tjustice
Sorry, 2005......
Old Jun 29, 2012 | 06:54 AM
Rusty Axlerod's Avatar
Rusty Axlerod
How did it go from oil pressure issue to head gaskets?
Old Jun 29, 2012 | 07:01 AM
tjustice's Avatar
tjustice
Missing coolant in Degas bottle...Which turned out to be the case, they was leaking not bad but still leaking.....Wasn't original issue, just trying to fix all at once, while had some spare $$$$$ and time.....
Old Jun 29, 2012 | 07:49 AM
AGE mechanic's Avatar
AGE mechanic
You should consider BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 while your at this point.
Old Jun 29, 2012 | 09:13 AM
2006powerstroke90's Avatar
2006powerstroke90
So a failed IPR? Replace it and be on your way.
Old Jun 29, 2012 | 04:08 PM
npccpartsman's Avatar
npccpartsman
Could easily be an STC fitting since it's a 2005.
Old Jun 29, 2012 | 05:26 PM
tjustice's Avatar
tjustice
STC fitting was upgraded about a year ago....
Old Jun 29, 2012 | 10:56 PM
_Me2_'s Avatar
_Me2_
Hard to say without more info. I'm thinking air test to narrow down a leak, or possibly HPOP.
Old Jun 30, 2012 | 12:02 AM
BLADE35's Avatar
BLADE35
I hope yyour using ARP Head studs and OEM Headgaskets
Old Jun 30, 2012 | 06:24 AM
tjustice's Avatar
tjustice
Yes sir, going back with ARPs and OEM gaskets, water pump, oil cooler, thermostat, HPOP is there anything else I can do?.....EGR delete was done already (Sinister)
Old Jun 30, 2012 | 07:39 AM
AGE mechanic
Yes there is
95 taco
Sep 25, 2017 03:57 PM
wolffee
Mar 1, 2016 07:27 AM
KJD3
Dec 1, 2015 07:27 AM
Will Bite
Sep 16, 2012 08:14 AM
BigCrzyRdNeck
Jan 30, 2011 10:27 PM
