HPOP PROBLEM/HEAD?
Old Jan 28, 2011 | 03:32 PM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
Unhappy HPOP PROBLEM/HEAD?
my 96 stroke begin starting hard after sitting for 30+mins cold or hot and now after 3 min. i pulled the valve covers and and onthe driver side the oil return on all 4 inject. is good and steady but on the pass. it barley seaps out on all 4 when running trying to find out if the oil hose can collapse on the in side or the pump is going. runs fairly smooth considering but in gear with brake on you can diffently feel shake. has anyone has this or know of what might be going wrong thanks for all the help
Old Jan 28, 2011 | 07:24 PM
F350-6's Avatar
F350-6
That's usually a sign of a blown injector o-ring or two. It's bleeding off excess pressure. Get a set of Ford / International / Alliant o-rings for the injectors. Don't get the cheap ones from the parts store.
Old Jan 28, 2011 | 09:00 PM
BigCrzyRdNeck
ok i did read AFTER i put it back togther to look at the base of the injector at teh head to look for oil comming out. so would this be one or a few injectors that needed and ive heard of them going out but how ofthen do they go out had the truck for 5 or 6 yrs and ive put a few injectors in it but never any o rings and thanks for the help
Old Jan 29, 2011 | 09:53 PM
BigCrzyRdNeck
ok i changed out one injector with one i know is good and the oil is a little more coming out the out spouts but still real weak compared to the driver side do maltiple o-rings go bad at once or injectors and on the same side? i do want to put a guage on the oil line to compare the two sides when i did a koer test the psi said 3000 i think at idle but then again the drive side looks good at the spouts
Old Jan 30, 2011 | 07:47 PM
BigCrzyRdNeck
f350-6 can i get a 0-5000 psi hydralic gauge and put it inline of my oil hose to compare line psi or would that not work the way i want?
Old Jan 30, 2011 | 08:00 PM
F350-6's Avatar
F350-6
That would work, but getting it inline is difficult. The easy way to do it is use one of the fittings in the oil rail on the inboard side of the head. You can remove the plug and plumb your gauge into that hole. You can also use the ICP sensor hole on the driver side for the gauge.
Old Jan 30, 2011 | 10:27 PM
BigCrzyRdNeck
ok now i just need to pick up a guage. also i read on here one quik way to get air out is to drive at higher rpms so last night i ran no overdrive which is 45 mph at 2500 rpm in for about 15-20 min and when i went to back in my drive way it all of asudden felt like it started running on 7 cylinders when i check monday i hope it still is so i can maybe find my main problem
