A little rough
Old Jun 28, 2012 | 03:56 PM
AmongHidden's Avatar
AmongHidden
A little rough
Ok so my 1974 f250 is running but running rough. Namely when idling, it will idle and try to quite. I'm thinking about doing a Seafoam treatment or a Gumout regane. Also my truck doesn't like to start until I pour some gas down the carb. If anbody know what might be wrong and how to fix it then that would be very helpful.
Old Jun 28, 2012 | 09:47 PM
VocaTexas's Avatar
VocaTexas
First thing to check is the carb mounting nuts. If the carb is loose, it will suck air under it and it won't idle right. If that isn't it, I'd check to make sure the fuel pump is putting out enough fuel volume and pressure.
Old Jun 28, 2012 | 10:05 PM
fmc400's Avatar
fmc400
MSEE
Time to hook up a vacuum gauge. In terms of Seafoam treatment, you can't identify a solution without first identifying the problem.
Old Jun 29, 2012 | 12:05 AM
bamaf150's Avatar
bamaf150
Sounds like a bad accelerator pump in the carb for one issue, that might be why youre having to pour gas in it
Beastie
Mar 12, 2013 06:18 PM
mikemustang289
Aug 14, 2011 10:40 PM
2010Iron883
Feb 24, 2011 08:43 PM
grandpas68
Oct 30, 2009 11:55 PM
Shane269
31
Jul 21, 2005 09:29 AM
