emergency cable routing
Old Jun 28, 2012 | 11:26 AM
gsato55's Avatar
gsato55
Just wondering if anyone knows exactly where the cable passes through the firewall before it attaches to the handle on a 56 F100? A picture would be most helpful.
Thanks in Advance
Glenn
Copperas Cove,Tx
Old Jun 28, 2012 | 11:40 AM
das54's Avatar
das54
On my 54 it lays against the floorboard above the steering column and runs thru the transmission cover at the front left corner. The floor board and transmission cover have a indent that forms a low angle hole. I used a piece of heater hose to seal it. I suppose someone makes a foam seal.
Old Jun 28, 2012 | 11:41 AM
CharlieLed's Avatar
CharlieLed
It doesn't pass through the firewall at all...it comes up through the transmission cover opening. Take a look at the floor panel around the transmission access opening and at about 11 o'clock you will see an indent...that's for the cable to pass through.
Old Jun 28, 2012 | 12:18 PM
gsato55's Avatar
gsato55
Thanks Dan and charlieLed for the info. I see the indent on the original cover. I fabricated my own cover so was not aware of the indent. Thanks so much.
Glenn
Copperas Cove, Tx
56 F100
Old Jun 28, 2012 | 03:27 PM
das54's Avatar
das54
Yea, I wanted to weld my tranny cover like I did the battery cover to avoid the bolted seam but didn't want to figure out how to get the cable thru the floor so I left it original.
So how is the speedo cable routed.
barryjdi
Mar 18, 2015 11:10 PM
woodtrucker
Jul 18, 2013 07:34 AM
dailydrvr
Nov 4, 2009 09:05 AM
tip49
Aug 21, 2007 02:30 PM
Tetchy101
1978 - 1996 Big Bronco
Jul 12, 2002 02:43 PM
