Sponsored by: Real Truck
short bed swap
Old Jun 26, 2012 | 11:15 PM
magicsac1366's Avatar
magicsac1366
short bed swap
anybody done this? i mean, take a truck with a long bed, cut the frame, swap out the fuel tank, cut down the drive shaft, and put a short bed on. specificaly a 2wd regular cab truck.
i've seen a few of them, but nobody shows the work, just the results... im interested to see what the pictures look like, how you stiffen the frame, what you do with your fuel lines, e brake cables, etc...
Old Jun 26, 2012 | 11:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Most local body shows wont cut frames. But there are some specialty shops that do stretch that will do it. Give them a call for pics.
Old Jul 1, 2012 | 10:12 PM
BigBlackX's Avatar
BigBlackX
chopping frames
I did it on a 1979 f150 when i was 17. cut the frame at the back of the cab and welded back together, added c channel for 12 inches to "box" that section for strength. I ran it hard following my buddys on their dirt bikes and the guy I sold it to used it for mud runs with no problems.
I did it again a few years ago to convert a long flatbed into a 8' bed utility bodied truck. Cut the frame on an angle to have more shear strength and put diamond shape gussets over the cut and welded area. Checked welded area religiously for awhile, now it gets checked once a year for DOT and no signs of stress, and that truck hauls 10,000 pound generator trailers for a living! I ran new brake line and converted that trucks ebrake cables to short wheelbase cables, used heatshrink type fuel line to splice the cut section back together. I WOULD NOT recommend learning how to weld on this project. A large truck repair garage will quite often be willing to do this modification as they do big truck frame cuts fairly regularly while upfitting a truck, body shops usually pass unless its a no paperwork, cash deal.
Old Jul 2, 2012 | 06:43 AM
redford's Avatar
redford
FTE Leadership Emeritus
If I was going to go to the trouble, I would go one step further to make the truck stand out, like maybe a step-side bed.
Old Jul 2, 2012 | 11:42 AM
sammy77's Avatar
sammy77
Too much work IMO... Find a short bed and purchase.
Old Jul 2, 2012 | 04:22 PM
wizardsr's Avatar
wizardsr
When did ford make a regular cab shortbed super duty???
I'd love to do this with an F250 4x4 for plowing driveways. An 05+ with coil springs and shortbox would practically turn on a dime.
Old Jul 2, 2012 | 05:31 PM
redford's Avatar
redford
They make them in Mexico, 2WD only, and you can't import one.
Old Jul 2, 2012 | 07:54 PM
BigBlackX's Avatar
BigBlackX
SO, what youre saying is that Ford makes a "standard cab, shortbed" super duty in Mexico?! I have never heard that and can't seem to find any images of such a vehicle, although Ford has done some wierd stuff over the years... Could it be that the trucks you speak of are the airport trucks that are super short?
If they do exist, as you say, then you could drag a frame home I would think? And use it to build a u.s. vin tagged truck... Although that seems like alot of unnecessary steps when a gas hatchet and a stick welder could give you the same basic thing, haha.
Old Jul 2, 2012 | 11:08 PM
2002 F350V10's Avatar
2002 F350V10
they do, with different drivetrains, and they import them to australia and bolivia and the likes. search some foreign ford sites and you will see them. Some are even right hand drive. They also usually have dated tooling and may not even offer our current styles yet.
Old Jul 12, 2012 | 10:06 AM
magicsac1366
Looks like ill be keeping an eye out for a nice looking 6' bed in my color, or maybe black... Either way, when ever it happens ill post pictures of the process
Old Jul 12, 2012 | 10:49 AM
SteveH-CO's Avatar
SteveH-CO
I thought if you wanted a short vehicle for plowing, you'd use an old Bronco ;-). I'd rather have the long bed (reg cab) for plowing - gives the truck more stability when pushing huge amounts of snow.
I think a reg-cab shortbed SD would be cool - and unique. Not the dumbest home-made truck project we've ever seen.
Old Jul 12, 2012 | 11:36 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
https://www.ford-trucks.com/forums/5...ml#post4788831
Old Jul 12, 2012 | 03:42 PM
grec-o-face's Avatar
grec-o-face
For long, heavy pushes, yes. A longer wheelbase is nice (with the right ballast of course).
BUT, for driveway work, short-bus all the way. I went from a SCSB to a CCSB (not much of an increase in wheelbase really) and noticed a Major difference for driveway plowing. Add to it, the lame turning radius of a leaf sprung front end...
MR KROGOTH
19
Jun 8, 2016 08:38 PM
Nightrain
Jan 9, 2007 08:22 PM
70sc
13
Feb 13, 2005 12:29 PM
arsetard
23
Nov 2, 2004 02:06 AM
dandude2103
Jan 8, 2004 03:48 PM
