Typical underhood temp?
Old Jun 26, 2012 | 05:39 PM
NW 150's Avatar
NW 150
What is the typical underhood temp in one of these trucks with a v8 that has unwrapped headers on it? My gas line from the pump to the carb is getting to hot and is taking away the power because of the hotter temp gas. I have reflective tape I want to try but need to know if it will withstand the heat under the hood first...
Old Jun 26, 2012 | 05:44 PM
PRIMERED79 SHORT BED's Avatar
I feel your pain.
Yesterday mine started to vapor lock for the first time since I owned it.
I ordered some heat sleeve last night to combat the heat.
As Far as the heat, I know I checked my temps yesterday and my fuel pump alone was 200 degrees when I parked when I got home.
The fuel line that goes to the
Carb was running around 170 degrees.
Oh mines a stock 400 with stock manifolds.
Old Jun 26, 2012 | 05:55 PM
NW 150's Avatar
NW 150
Yea I have some reflective tape that's rated at 200 degrees and I want to wrap it around the line to the carb. Just seeing if it would hold up, because when the gas isn't hot, the thing has some pretty good power.
Adam Woolridge
Jul 15, 2019 12:44 PM
bigfoot22
Jun 11, 2016 09:05 PM
1978Crew
Oct 29, 2004 09:20 PM
superswamper
Jul 28, 2003 11:49 PM
