OK Guys, Many of you helped me with my egr delete and oil cooler change. It seems to be running perfect atm the moment with one exception. It has happened 3 times now. It will start and run smoothly then up and just die. It did it to me at the stop light outside my job today. I had to crank it over for a minute or so and pump the pedal a little and it finally cranked back up and is running perfect again. What gives? whats it trying to tell me?
I do and the voltage is right at 48. I've only had this truck for less than a month. I was told the FICM had been reprogrammed when i bought it. My local guy just told me that if it was not done correctly it can cause this problem. I just wanted some advice from here before i let them flash it for me.
check the icp when it happens. you can pull the screen and check to see if it is damged, covered in debris or sucked in, any of the 3 is a reason to replace it.
this is common after an oil cooler. comes from either not cleaning well enugh around the oil cooler or not using a lint free rag when do so.
My ICP readings are 550 at idle and my IPR is sittin at approx 22.4, these seem like low Stats I've read that 15% - 85% are good for the IPR any thoughts?
