6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Newbie
Old Jun 24, 2012 | 03:23 PM
TX offroad's Avatar
TX offroad
Newbie
I just recently switch from a chevrolet colorado and bought Ford F250 and really don't know much about the maintence of these vehicles. When do you normally change the oil and filter and the fuel filters. If ya'll can give me any advise that would be greatly appriecated.
Old Jun 24, 2012 | 03:58 PM
CountryAggie's Avatar
CountryAggie
Need some more details, it makes a big difference.
Year? Gas/Diesel? 2WD/4WD? Mileage?
Old Jun 24, 2012 | 05:11 PM
TX offroad's Avatar
TX offroad
Oh yea that might happen, it's a 2008 diesel with the 6.4 in it, has 51k miles on it. It is a 4x4 with a lift. I'm not sure what the prev ious owner has done to it. I do know it is gonna need new tires tho any recomendations?
Old Jun 24, 2012 | 05:44 PM
ljutic ss's Avatar
ljutic ss
You start out by changing all fluids and filters on the truck except the front and rear differentials. Coolant, motor oil, power steering, transmission, and transfer case oils, this way you are on a known maintaince schedule.
Old Jun 24, 2012 | 05:49 PM
CountryAggie
Then once you change out all the fluids, decide if you want to delete the DPF/DoC and EGR or not. If you don't delete your DPF, follow the "severe" maintenance suggested cycle. Once you delete you can stretch out the oil change intervals, but still change all the filters and other fluids following a normal suggested interval based on your manual.
Old Jun 24, 2012 | 06:51 PM
senix's Avatar
senix
register here by your vin and check out all the owners manuals. Follow the severe maint sch. and use only OEM filters.
Official Ford Owner Site | Schedule Vehicle Maintenance, Get Tips, Advice & Coupons
Old Jun 24, 2012 | 10:13 PM
RM2738's Avatar
RM2738
5K oil & filter, 10K fuel. You'll be due for coolant at 60K.
Welcome to the FTE!
Old Jun 25, 2012 | 08:09 AM
Gearitis's Avatar
Gearitis
Get under that truck right under the Drivers door, look up and you will see a yellow lever. Put a 32 oz cup or bigger under it and open that lever and let it drain for 5 minutes or so. That way you will get water out of the system to that point. We do not need to allow water in the fuel system. Just plan on this schedule at least monthly, I try to do it every 2 weeks.
Old Jun 25, 2012 | 06:58 PM
CountryAggie
32oz is a lot! That means you are losing a gallon every month! It only takes draining until you see clean diesel. If you are draining enough water to fill up a 32 oz cup even every month you need to find a different gas station.
Old Jun 25, 2012 | 07:18 PM
RM2738's Avatar
RM2738
32 oz is not a lot, compared to the 5 minutes of flow! 5 minutes might get you at least a gallon, maybe two!
Old Jun 25, 2012 | 09:38 PM
tgreening's Avatar
tgreening
On the fluid change, I would recommend at least checking the fluid in the diffs. Lifted 4x4 generally means the driver at some point thinks he's driving a boat and wants to see just how deep he can go before having to swim for it.
In reality the water doesn't have to be all that deep to submerge your diffs and axle tubes. In the overall scheme of things it's cheap preventative maintenance.
13razorbackfan
Sep 17, 2017 02:07 PM
995.4SD
Oct 27, 2011 09:31 PM
dendans
Jan 21, 2009 06:23 PM
JRF
General Diesel Discussion
Jun 22, 2007 02:20 AM
Bear1971
Feb 27, 2003 09:15 PM
