Broken exhaust manifold bolt
Start my Excursion project today, I have to air test the Ex and in the last couple of weeks it has what I thought was bad up pipes. Nope, broke exhaust manifold bolt and it looks flush with the head. Ok, who has the tool and how long did it take on the driver's side(I know I lucked out there) Lisle 71350 looks like the ticket as far as price goes or run over to my buddy's machine shop and make one. I think it's time to reconsider putting any more time and money into the Ex, it's a shame too it ran so good.
I was thinking the same thing, It's in a bad spot to get the drill in there though. I might have to take the manifold off and who knows if the other ones are going to break. Being that I retired, a bunch of people want me to work on their trucks. It might be in my best interest to get the tool thou.
OP -=- not sure what cylinder is involved: Cyl 6 and Cyl 8 uppers and lowers are serviceable with a right angle drill (I typically pull the inner fender panel, pull the intake and be extremely careful with that panel where it ties into the main harness). Cyl 2 and Cyl 4 uppers and lowers will be a challenge depending on the type of drill setup you're using --- some air driven right angle drills can get in extremely tight places but tend to be less controllable, ditto corded, probably best to stay with cordless/battery driven.
Not being that at all, but since you got testy and nasty, just wanted to point out the regulator has little to do with actual tool (precision) control --- application of torque, RPMs, etc. Of course regulation of psi matters but less so than the precision built into the triggering/actuation/governor on the tool itself. Electrical devices have long used linear potentiometers, chips, etc to control triggering which results in far better precision. Pneumatics aren't at this level yet.......
BTW -- unless you have some survey, poll, etc don't make generalizations about "people".............bad form.
