Shudder question
Old Jun 23, 2012 | 11:38 PM
rusty9cab's Avatar
rusty9cab
Shudder question
If the torque converter is shuddering, should there be a spike or increase in transmission temp? I have a slight shudder on initial acceleration that I am trying to pin point. I have a larger tranny cooler and normally run about 155 to 160 degree transmission temps on an 85-90 degree day. It's possible the shudder could be coming from the injectors, as they are original and have 247,000 miles on them. What do you guys think? Or, do you have any other ideas?
Old Jun 24, 2012 | 05:55 AM
427 fordman's Avatar
427 fordman
I have noticed the same thing towing my trailer on a couple occasions, not often. My thought is the convertor. I know its a matter of time, but I take off real easy if I can.
Old Jun 24, 2012 | 08:01 AM
cornbinder's Avatar
cornbinder
it's the converter, my 94 idit does it, i keep the fluid changed more frequently ( every10k miles cheap insuranceLOL), added a really big cooler and a larger aluminum tranny pan. it doesn't matter it still does it sometimes just not as much or as bad.
Old Jun 25, 2012 | 12:21 AM
rusty9cab's Avatar
rusty9cab
Thanks guys. The tranny is Ford reman unit that only has 13000 miles. I will change the fluid. Do you guys think I should upgrade the converter or is there anything else that can be done to raise the clamping force?
Old Jun 25, 2012 | 04:57 AM
427 fordman
With that low of miles, and if you tow a lot/use it hard and money allowed, I'd sure give it some strong concideration.
BURNSTOUGHFORD
1997 - 2003 F150
Apr 11, 2010 03:05 PM
nightfalcon89
1997 - 2003 F150
Apr 11, 2010 09:32 AM
Uglyhat
Oct 24, 2005 05:32 PM
