Frame restoration
Old Jun 23, 2012 | 11:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Frame restoration
I am in the middle of redoing my 97 CCSB.
The entire truck was coated with Zeibart when new and it helped preserve the frame. It worked well where it stuck, but where it came off I had pitting.
In order to remove the Zeibart, I used a heated power washer to strip the frame(the black is where the zeibart WAS)
I then sandblasted the entire frame(I made a 4" body lift to give me room to work)
Tomorrow i will POR15 2 coats then 2 coats of Tractor supply Lo-glare black
Old Jun 23, 2012 | 11:17 PM
fdude64's Avatar
fdude64
looks good. i did a similar restore on my 95 f350 but my frame was in alot worse shape. you can look at my build thread and see what all i went through. even my "better" frame was not in that good of shape
Old Jun 24, 2012 | 10:21 AM
BigBlueOx's Avatar
BigBlueOx
I spray my frame with a mixture of used motor oil and a hint of kerosene to thin it every year. It doesn't look pretty but it works and the bolts on the underside never riquire heat to remove them.
Old Jun 24, 2012 | 05:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
she's going to look some nice soon.
sure takes a long time though.by the time you apply the marine clean,then prep and ready,then spray,then wait until it dries a bit,then re-coat,then dries until just tacky again,then topcoat.it's all worth it of course.
your having a good long day of it out there im sue Brad.looking forward to the pics.
nothing beats the looks of a fresh coat of por15.it's like brand new all over again,only better.
Old Jun 24, 2012 | 07:16 PM
Diesel_Brad
No need for marine clean or metal ready when sandblasted. Just put it on. Took me about 4 hours total worth of painting
here is 5 quarts of POR and 4 quarts of TSC lo-glare black
Old Jun 24, 2012 | 07:47 PM
BrianDguy's Avatar
BrianDguy
Wow, looks awesome!
I just did my 97s frame with Chassis saver and I'm not really impressed with it. Next time I won't be cheap, and pony up for the POR15.
Old Jun 24, 2012 | 09:49 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Is POR15 as good as Line-X? In terms of durability?
Old Jun 25, 2012 | 01:22 AM
RJJP's Avatar
RJJP
10 characters
Old Jun 25, 2012 | 06:35 AM
ncranchero's Avatar
ncranchero
I had to change the frame on a wrecked 86 F150 4x4 I bought back in the late 87. I cleaned painted, spent countless hours making it look better than factory new. Reassembled the truck and within a month the undersides looked like all of the rest of the pickups on the road & I didn't off-road it. Doing it for preservation is good, doing it for "pretty" is a total waste of time/effort. My $.02 worth.
Old Jun 25, 2012 | 10:05 AM
Diesel_Brad
2 totally different products that have different purposes.
And i didnt do it to make it pretty. I did it to preserve the frame and under side of truck
Old Jun 25, 2012 | 11:17 AM
IDIDieselJohn
Because I heard POR15 likes to peel off if you apply it to a shinny/smooth surface IE sand blasted metal, new metal etc....
Old Jun 25, 2012 | 12:05 PM
Diesel_Brad
Sandblasted metal is NOT smooth. That is probably the best bight any paint could get. Now new smooth metal, I wouldnt expect anything to stick to, it has no "tooth'
Old Jun 25, 2012 | 12:08 PM
Grubbworm's Avatar
Grubbworm
Since it is already sandblasted, I would clean and prep it and spray two coats of a 2-part epoxy primer on it. Properly applied to a properly prepped surface and it will be just as good if not better than POR-15. I would say it would be a personal preference on which one you would use.
Here are a couple of links worth reading.
what to put on rust
Question for Barry & the other pro's about surface prep before epoxy
Use SPI on top of POR15?
61 Buick
1965 Mustang rust repair
A woman's project: 1968 Mustang Fastback Eleanor
Rust converter
zero rust
Media Blasting, how clean is clean?
Good luck, and post plenty of pictures of your progress.
Old Jun 25, 2012 | 12:30 PM
Diesel_Brad
That site you linked to is SEVERELY biased.
that would be like going to a chevy forum and asking what kind of truck to buy
Old Jun 25, 2012 | 12:47 PM
ncranchero's Avatar
ncranchero
I've used POR15 and EXTEND with quite satisfactory results before. Line-X or similar is not a rust treatment.
