Not getting third gear or O/D
Old Jun 22, 2012 | 04:43 PM
spicolas's Avatar
spicolas
I just bought a 1997 f350 460 with 84,000 miles. When I put it in drive it wont shift out of first gear. If I shift manually I can get first and then second and they both work fine, if I go back to drive to hit third it goes into neutral and doesn't re-engage until the speed drops and then it goes back into first. atf looks fine and doesn't smell. Perhaps sight unseen internet auctions are not the right way to get a good deal...
Old Jun 22, 2012 | 11:11 PM
powerstroke72's Avatar
powerstroke72
Moved to the Clutch, Transmission, Differential, Axle & Transfer Case forum.
Old Jun 23, 2012 | 12:35 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Could be a valve body, solenoid, or direct clutch. Does reverse work? Reverse also uses the direct clutch.
1972fordhighboy2
Dec 17, 2024 02:19 AM
oldblue89
35
Jul 16, 2021 06:34 PM
91f2504x4
21
Jan 23, 2009 12:56 PM
79-400-POWER
1983 - 2012 Ranger & B-Series
Nov 12, 2008 10:38 PM
doosky2k
Jan 8, 2005 02:18 PM
