Injector hose
Old Jun 22, 2012 | 08:57 AM
Polkster's Avatar
Polkster
Injector hose
2000 f-450 7.3l diesel powerstroke turbo.
Right rear injector hose spraying diesel.
Any links or advice on going about to fix, replace it?
Thank you in advance,
Steve
601-940-5699
Old Jun 22, 2012 | 09:00 AM
fordpride's Avatar
fordpride
Have you tried to tighten it?
Old Jun 22, 2012 | 09:04 AM
fordpride's Avatar
fordpride
Is it the fitting in the head or where the line mates to the fitting?
They have these in between the line and fitting
Parker 60VLV-5 Viton Sleeve 5/16 inch
Old Jun 22, 2012 | 09:07 AM
Polkster's Avatar
Polkster
No sir, havent really seen it, just where mechanic said was leaking from. was really wondering do i need to take all turbo pipes off in order to get to it to replace it. We are letting motor cool off now so we can get to it.
Thanks.
Old Jun 22, 2012 | 09:08 AM
Polkster's Avatar
Polkster
He said it was spaying out of center of hose and needs to be replaced.
Old Jun 22, 2012 | 09:09 AM
fordpride's Avatar
fordpride
I don't think you have to take the down pipe off
Old Jun 22, 2012 | 09:33 AM
Polkster's Avatar
Polkster
We've found the hose. Fuel delivery line left cylinder head.
Getting it off and replaced without taking turbo hoses off.
Thanks for thr help.
Old Jun 22, 2012 | 10:10 AM
Polkster's Avatar
Polkster
where the clamp around metal fuel line was was where the hose was worn a hole in it from vibaration.
Old Jun 22, 2012 | 11:06 AM
PaysonPSD's Avatar
PaysonPSD
I put a piece of split fuel hose around that point to prevent wear.
Anyone with an Early 99 should also check the driverside fuel line. Mine was making contact with the IPR nut. You can see the groove in the hose I added where it makes contact. 99.5 and up have a different bend in the fuel line and this is not a problem.
Old Jun 22, 2012 | 11:26 AM
Polkster's Avatar
Polkster
Thanks payson. wish i would have seen this 1st. we loaded it up with lotsa black tape.
Old Jun 22, 2012 | 11:38 AM
PaysonPSD's Avatar
PaysonPSD
At least you took some preventative measure.
My original post on 07-01-2011.
Old Jun 22, 2012 | 03:03 PM
hammer65's Avatar
hammer65
Payson: Do you know if this a problem on 2003 engines as well?
Thanks Jim
Old Jun 22, 2012 | 03:41 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Jim
If there is a p-clamp on the passenger side fuel line take prevetative measures. Driver side on 99.5 and later unlikely. Aways best to take a look.
Chris Karsseboom
Jan 11, 2016 05:12 PM
2006powerstroke90
Jan 20, 2011 06:16 PM
tndiesel
Feb 10, 2009 03:27 PM
slk133
Jun 9, 2008 06:35 PM
chick
Jul 28, 2007 02:15 PM
