Payload 1,000lbs?
Old Jun 18, 2012 | 10:41 PM
Dutch123's Avatar
Dutch123
Payload 1,000lbs?
Read posts on payload. I have three pallets each 1,000lbs-Is there an agreed upon position for the pallet: that is, closer the tailgate or nearer to the cab?
Old Jun 18, 2012 | 10:49 PM
QwkTrip's Avatar
QwkTrip
Centered over the rear axle, if you can. Otherwise toward the front for lower rotating inertia.
Old Jun 18, 2012 | 11:01 PM
flixden's Avatar
flixden
As close as possible to the cab is what I would do. The majority of the load will still be on the rear axle, but that way you put a little bit of it to the front as well. You are going to take them one-by-one, right?
Old Jun 18, 2012 | 11:24 PM
QwkTrip's Avatar
QwkTrip
To the OP, 1000 pounds is really no big deal, you know. Just strap it properly so it doesn't slide if you have to stop suddenly.
Old Jun 19, 2012 | 06:19 AM
Dutch123's Avatar
Dutch123
Ok- I have The Roll-N-Lock takes that space nearest cab: yes, 3 trips- centered over rear axle and strapped:
Old Jun 21, 2012 | 10:43 AM
edlEBBY's Avatar
edlEBBY
what is a roll n lock?
Old Jun 21, 2012 | 11:22 AM
flixden's Avatar
flixden
Roll-N-Lock retractable aluminum truck bed cover
Old Jun 21, 2012 | 09:13 PM
capn kirk's Avatar
capn kirk
I know going over payload rating is bad but sometimes you gotta do what you gotta do for work, but 1000lbs is no problem. Most ive had in the bed so far is around 2500lbs maybe 2700 in my 2011 150. Only gone to or over 2000lbs about 3 times or so, squats down a lot but never had a problem the 2700 load got too close to the bump stops for comfort so I will probably be getting air bags. Drive safe give yourself room when you have extra weight and you'll be fine
Old Jun 22, 2012 | 09:45 PM
Dutch123's Avatar
Dutch123
Sheesh 2grand+lbs! that's bada**!! 1k aint nuttin then
Old Jun 22, 2012 | 10:15 PM
1969furd's Avatar
1969furd
i know is for hte 150s but i had a 79 f250 that i had 3800 lbs in the bed, and it squtted pretty good too
Old Jun 22, 2012 | 11:36 PM
Dutch123's Avatar
Dutch123
you could haul a Pinto in that 79!
backtrack2015
All Things Towing
30
Oct 13, 2017 02:39 PM
'83f3fiddy
23
Mar 19, 2011 02:09 PM
1969furd
Dec 29, 2010 03:33 PM
RoccoV
Jul 29, 2006 08:58 PM
tdamore
Feb 12, 2002 10:44 AM
