Now that I've said hello, the first question I have is does anyone know how to remove the overhead console on a 2012 F-250 ? I would like to tap into the wiring to power my radar detector. Any help would be appreciated.
Pull the rear edge of the overhead console downward, at the locations shown, and then pull rearward.
Disconnect the electrical connectors.
Remove the overhead console.
To install, reverse the removal procedure.
Make sure to align the overhead console retaining clips to the adjacent clip holes.
Hope this is what your looking for.
good luck,
wade
<?xml version="1.0" encoding="utf-8"?>
Hey Wade, thanks for the reply. The pictures didn't come through on your post however for some reason. I'll PM you and give you my e-mail address if you could e-mail me this info that would be great
Wade came through, got the console pulled and radar detector hooked up. Thanks again Wade.
I've been trying to find a good way to mount my Valentine One V1 radar detector and was having a bear of a time getting the visor clip to slip up over the headliner where I wanted it. And I considered hard line powering the detector off the 12V source to the map lights in the console. I ended up hard wiring it to an upfitter switch instead, but I still wanted to pull down the overhead two-compartment console in my 2011 F250. It turns out it's really easy.
Reach up to the foward-most corners of the plastic part, nearest the windshield, and start pulling it down. It's just fiction clips in there. Then work your way toward the back, pulling it down. Takes just a couple of seconds. Easy peasy.
