Does anyone have a source for a 95/96 MAF 5.0 intake hose? My 86 has the mass air conversion, and I the need to setup that splits the larger intake into the dual throttle body. Can't find one in any of the boneyards around here, nor on eBay. Any help would be appreciated.
Thanks...appreciate you forwarding this. You're right, it's really more than I need. I just had the two small hoses between y and the throttle body split. I've tried the boneyards, but none to be had around here. I think i might have found a solution with some odd sized flexible radiator hoses available from Goodyear...just need to wrestle the truck away from my son long enough to do some measurements. I'll post the part numbers for others if it proves to be a workable solution.
Just in case someone else runs into the problem with the hoses at the throttle body splitting, a universal flex hose with the right measurements is the Goodyear 53611. Dimensions are 2 1/4 x 11 inches.
