Using LEDs in our trucks.
Old Jun 17, 2012 | 05:39 PM
MikeS29's Avatar
MikeS29
I have read many threads talking about converting certain elements to LED: Taillights, Headlights, Signals, Instrument Cluster Lights etc.
I'm interested in the idea (though not sold) on turning any lightbulb I can into an LED (Light Emitting Diode).
  • Secrets?
  • Tips?
  • Electrical info?
  • Favorite Supplier?
  • Advantages?
  • Drawbacks?
  • Costs?
Thanks for any info you can provide.
Grazie,
Old Jun 17, 2012 | 05:50 PM
hermancm's Avatar
hermancm
I just converted six of the nine lamps on my cluster to LEDs. I have to wait for our long day to be over to see hw they look. I didn't do the turn signals or the high bright indicator mainly just because I didn't think it took nine lamps altogether. I bought my LEDs on eBay, they have 5 LED spots on each lamp. I've heard of some lamps having errors but I'm not sure how that is... But the so called perfect lamps are very expensive! I got all six of my LEDs for $15 shipped. I'll post an update later after I've seen them at night.
Old Jun 17, 2012 | 05:56 PM
MikeS29's Avatar
MikeS29
Great deal, look forward to hearing more of your story and seeing some pics.
Your post was one I had just read and I had already been thinking about it for taillights, but then I got thinking, "why not everything?"
Old Jun 17, 2012 | 06:02 PM
fmc400's Avatar
fmc400
MSEE
The main thing to be careful with on these trucks is bulbs that are in the turn signal circuit. The turn signal flasher is a thermal type and requires a set amount of current to pass through it to blink on and off at the proper rate. Because LED bulbs draw significantly less current, they don't draw enough to make the flasher cycle. If you want to run LED bulbs in every possible place, you'll need to use an electronic flasher.
Old Jun 17, 2012 | 06:17 PM
MikeS29's Avatar
MikeS29
Yes, this is the kind of information I need. Thanks... I have work to do in figuring all this out.
Old Jun 17, 2012 | 06:30 PM
MikeS29's Avatar
MikeS29
oops, modes delete please
Last edited by MikeS29; Jun 17, 2012 at 06:47 PM. Reason: new thread, accidentally attached to old thread!
Old Jun 17, 2012 | 06:38 PM
MikeS29's Avatar
MikeS29
oops, wrong thread, please delete
Old Jun 17, 2012 | 08:38 PM
hermancm's Avatar
hermancm
Soo... I guess it worked out good that I didn't put LEDs in the turn signal indicators. I don't think I'll be doing much else as far as LED changeovers. I did it in the instrument cluster because I thought it was too dark. But I did change the front parking light sockets to a newer style and longer lasting 3057 bulb type. The sockets were listed as a GM type but they turned into the lenses correctly. The old lamp sockets were rusty and shot so the fix was needed.
Old Jun 17, 2012 | 09:59 PM
Stinky7-11's Avatar
Stinky7-11
Check this out, this guy has top quality LED's for all locations and you can call him with any problems, her has extensive electrical/lighting background. Got mine here, my instrument panel LED's are bright, the right shade and they dim perfectly.
LED Bulbs & Gauge Light Kits - LED Gauge Lighting Kits - HiPo Parts Garage
Old Jun 17, 2012 | 11:43 PM
MikeS29's Avatar
MikeS29
Wow, Stinky, that's great info. Just bookmarked it. Going to definitely go LED where I can, especially for brake and tail lights.
Old Jun 18, 2012 | 12:27 AM
Stinky7-11's Avatar
Stinky7-11
Glad I could help!
Old Jun 18, 2012 | 08:00 AM
POPAJON's Avatar
POPAJON
@ Stinky, Hey thanks, I just went through ALL the info on his web page and that is good stuff to know. Thanks for sharing the info. Popa John
Old Jun 18, 2012 | 03:04 PM
brian1080's Avatar
brian1080
I've got led bulbs and the correct flasher for my truck just waiting to go in. I got them for my galant, but the truck uses the same ones. I bought them here: LED Lights For Cars | LED Bulbs | 12 Volt - Super Bright LEDs
The flasher is nothing exciting, it just plugs in the same as the original.
Old Jun 18, 2012 | 05:50 PM
jim collins's Avatar
jim collins
I got the led kit for the instruments, blue, i only used the blue ones. Daylight hours to long in my area to see what they look like. I closed the shop doors one evening but still was not impressed with them,maybe cleaning the clear plastic inside might help. I do like the blue color.
I found out you do have to insert them like they say or they wont have a ground and wont work. I had to reach up in there and change one after i had installed every thing .
Old Jun 18, 2012 | 06:19 PM
buzzbomb's Avatar
buzzbomb
overseas.......
My son orders a LOT of camera stuff from china, the quality is good, and the shipping is FREE.
I am going to order led bulbs from this place
www.dx.com
It takes a little to look for the bulbs, but the prices are very cheap.
I'll let you know when I get them
Cheers
