New to forums. Quick Diff question.
Old Jun 17, 2012 | 04:38 PM
JimmyFX4's Avatar
JimmyFX4
To start, Hello. New here but been browsing for a bit as we just bought a 2003 Expedition FX4. Truck has 97k miles and the 5.4L Triton.
Ok so when turning slowly or from a stop you feel and hear a "rubbing" or "shuddering" sound. I've decided from reading around that this is MOST LIKELY the rear diff clutches and I just need to change out the Diff fluid and add 2 friction modifiers since its a little higher mileage.
Does this sound bout right to everyone? I did a wheel shake test and got no play in anything. All the wheels are the same size, 265/70/17 which is what the door tag says they should be. Nitto Terra Grapplers.. not sure that really matters though. Also did a visual check for any rubbing, The tire pressures are all similar as well.
So I guess the only question is... does this sound normal? And, if so... what kind/weight should be used? Is it just typical gear oil? And I'm not sure exactly what a friction modifier is.
Thanks for reading and for any help you may post.
Old Jun 17, 2012 | 05:20 PM
alwaysfords41's Avatar
alwaysfords41
Use the Ford specified fluid from the owners manual. Off hand I think it is 70 weight synthetic. The modifier is a small bottle used to keep the grinding away. Definitely use 2. You can find your manual here...
https://www.fleet.ford.com/maintenan...ls/default.asp
scottm1
Apr 19, 2017 10:21 AM
JoeVR5
1983 - 2012 Ranger & B-Series
Aug 8, 2011 10:45 AM
littlechuck
Oct 6, 2009 07:27 PM
95Z71
26
May 18, 2008 11:54 PM
Deleon
Jun 3, 2005 04:46 PM
