78/79 Adjustable Drag link???
Old May 7, 2003 | 09:41 AM
Dstroke's Avatar
Dstroke
I know this is a suspension question but its year specific, does anyone know if they make an adjustable drag link for a 1978 F250 4x4. I dont want the drop draglink offered by Super****. I just need a regular straight one. Part #'s and manufacturer would be great!!!!!
Old May 8, 2003 | 09:58 AM
Dstroke's Avatar
Dstroke
Question 78/79 Adjustable Drag link???
Anyone????????????
Old May 8, 2003 | 11:42 AM
jalampi's Avatar
jalampi
Why can't you use a stock drag link???
Old May 8, 2003 | 08:46 PM
Dstroke's Avatar
Dstroke
Im using a 2wd box and lost some of my turning radius. If I had an adjustable one I could get back what Ive lost.
Old May 8, 2003 | 11:02 PM
masterbeavis's Avatar
masterbeavis
Why not make one?? I am sure you can find the right parts to make one that is of decent quality at a price that wont kill you... (just make sure you do your homework, and use good quality parts) If you make something out of 2 turnbuckles, and some rebar welded together, you will prolly kill somebody, so use your head, and ask around for ideas on how to do it right.
Old May 8, 2003 | 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some of the racing specialty shops have parts to make this kind of stuff out of for the local short track racers.
Old May 9, 2003 | 07:57 AM
jalampi's Avatar
jalampi
Why dont you try a drag link from and 80s cheby truck.
Old May 10, 2003 | 09:18 AM
bad 78 f 250's Avatar
bad 78 f 250
i tried a chevy one it would not work different size tie rod ends and i tried every tie rod in auto zone to try and make it work it wasnt worth it so i bought one from 4x4 shop it was a lot easier and a lot safer then trying to rig one up hope this helps
bad 78 f 250
Old May 11, 2003 | 12:26 AM
1976 ranger's Avatar
1976 ranger
The part numbers i used are Es444L (2) tierod ends and Es2012s Sleeve. These are From carquest auto parts. They are the left front outer tierod end and sleeve for a 1978 Ford F250 4x4.
David
Old May 12, 2003 | 10:12 AM
Highboy70's Avatar
Highboy70
That's just the info I was looking for to finish off my project. I'm putting a 78 gearboPS) on my 74 F250 frame, and am using a "how to" that Sparky posted on this web site. I am doing it a little different, but he said he had problems steering to one side fully so the solution would be an adjustable center link(from pitman arm to steering knuckle).
I hope to take pics of the conversion and post them on the web site.
Thanks,
Old May 12, 2003 | 01:15 PM
stephenw's Avatar
stephenw
Hey David,
Thanks for the numbers, but want to clarify to be sure before I lay my money down?!? Does the adjusting sleeve have LH threads on both ends to match the LH tie rod end threads? I'm sure you get what I mean!?! Just want to be sure that things will mesh.
If this works, does anybody have a use for a MOOG drag link to fit a '78 3/4T 4x4? That's what I used originally when I did my conversion, but the steering box didn't quite center because the link was about 3/4" short, if I remember correctly, and think that may be why my steering is just a little bit looser than I would like.
I'm sure looking forward to trying this, so thanks again! Steve
Old May 12, 2003 | 08:08 PM
1976 ranger
Yes, according to the part store its left hand thread.
Old May 12, 2003 | 08:37 PM
stephenw's Avatar
stephenw
Thanks David-
Yes, I found out that the left-hand tie rod end has left-hand threads, but I believe that the adjusting sleeves typically have left-hand threads on one end, and right-hand on the other. That's the only way they could be used to adjust the toe-in that I can visualize, unless there's something I am overlooking here?!?
I went ahead and ordered in some pieces for tomorrow from my parts guy. He searched around and found a slightly shorter tie-rod end with 1" right-hand thread as needed to go with the sleeve. Unfortunately, the only right-hand tie-rod end that he could find has a metric nut on the tapered stud, but is the right taper!?! Anyway, I will let everybody know if it turns out "right" for me tomorrow, with a little bit of luck! Steve
Old May 12, 2003 | 08:49 PM
1976 ranger
Let me know what happens, I thought i used to left hands. Maybe i did use a right hand. Wait now that i think about it
the toe adjustment on a 78 F250 4x4 is not the same as a normal vechicle. As the right tie rod goes the full length of the front end. Typically a vechicle would have two adjustment sleeves. (one on each side were the Older F250"s have one on the drivers side. David
Old May 13, 2003 | 02:18 AM
Dstroke's Avatar
Dstroke
Well, for now I've solved the problem. I measured the rotation of the pitman arm and centered it. I then marked it and removed the pitman arm. I then filed the 4 indexing portions in the pitman arm. Then I rotated it about 3 notches and it works great. I still lack a little before it hits each stop so I will eventually get the adjustable link. Let me know if it works!!
