Steering Stabilizer In ...
Old Jun 18, 2012 | 11:47 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Thank you for the input.... It is nice to hear of others experience
Old Jun 21, 2012 | 09:24 AM
DevotedDad's Avatar
DevotedDad
Completed the package last night - Bilstein 5100s arrived and installed all the way around. Took it out on the same stretch of road (~50 miles) that I'd used after the stabilizer install ... no denying, the change is enormous ... rock solid, super comfortable ride. I'm glad I did this.
Old Jun 21, 2012 | 09:54 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
i swapped out my stock motorcraft shocks for 5100s at 200 miles and couldnt tell much of a difference really. I thought they were better, til i got them home to some familiar roads, then it was just as bouncy as before. the 5100s are pretty stiff when empty. good shock, but wasnt the night and day difference i had read about. then i swapped out the stock steering stab and that made a difference. night and day for sure. im goin to the 9000xls now and cant wait to see how the adjust-ability does.
Old Jun 21, 2012 | 10:05 AM
gsxr1300's Avatar
gsxr1300
I cant wait to hear your comparison of the 5100 to the 9000's
I started a thread the other day asking that question, no one replied
Old Jun 21, 2012 | 10:09 AM
Tuxedo Scorpion
well i havent tried em yet on the SD but ive been driving them on another vehicle and they are pretty smooth. again, still havent tried em on the truck on the local freeway that is like driving over a washboard. also just learned that the stock motorcrafts arent a true gas filled shock but are really a hydraulic shock, thus the return rate isnt immediate like the 5100s
Old Jun 21, 2012 | 10:15 AM
gsxr1300's Avatar
gsxr1300
ok thanks
so will you be trying them on the tuck?
Old Jun 21, 2012 | 10:22 AM
Tuxedo Scorpion
today!
Old Jun 21, 2012 | 10:31 AM
Andrew010's Avatar
Andrew010
Keep in mind his 'comparison' won't truly be apples to apples.
He had the bilsteins on a stock truck with stock wheels/tires.
The ranchos will be on a truck with 4" lift and 35" heavier MT tires.
It's going to drive/handle different mainly because of the lift and new tires.
Old Jun 21, 2012 | 10:32 AM
Andrew010's Avatar
Andrew010
Originally Posted by Tuxedo Scorpion
today!
Is rancho putting your new wheels/tires on for you? Or are you picking it up from rancho with the stockers still on it??
Old Jun 21, 2012 | 10:34 AM
Tuxedo Scorpion
they are puttin the new wheels on. but are doing testing in both configurations for comparisons
Old Jun 21, 2012 | 10:35 AM
Tuxedo Scorpion
based on your experience will this configuration smooth out the rigidity or amplify it
Andrew010's Avatar
Andrew010
Awesome. Starting to look more n more like Rancho is a top notch company.
Old Jun 21, 2012 | 10:40 AM
  #28
Tuxedo Scorpion
Ive seen nothing but strong evidence that they are nothing less. And to say ive been doing my homework is an understatement.
Old Jun 21, 2012 | 10:41 AM
  #29
Andrew010's Avatar
Andrew010
My tires are a little wider/heavier but they made it ride much firmer and took some of the 'body roll' feeling out of the corners. You can tell when you go over expansion joints/cracks in the road, it's a pretty solid feeling where as with the stock stuff it was more of a mushy feeling.
Hard to say what you're lift will do, as I don't know what springs (rate and specific/progressive) they installed. If it's a softer spring it's going to ride different than my stiff spring.
Old Jun 21, 2012 | 11:56 AM
  #30
Tuxedo Scorpion
Goin 75to down the freeway over expansion joints would cause such a violent bounce my kidneys hurt. With my stock shocks and the 5100s. And on my 08dads 6.4 non FX4
