F1 1949 Gearbox
It should be a direct swap out - Check to see if both use the 2 piece bellhousing, they both use the same emergency brake setup and that the rear transmission mounts are the same.
If you're going to do the swap it would be a good time to change the pilot bearing, the clutch disk and the throw out (Release) bearing.
If my information is not correct someone will be along to gleefully correct me.
I think the synchro trans is too long to fit in an F-1... read this article
https://www.ford-trucks.com/forums/1...-progress.html
The synchro trans is 2+ inches longer than the crashbox 4-sp. Just means more cutting of the crossmember and new fabrication is needed to use it.
No, we can't tell a thing without extensive pictures and more details. But in general, a truck that's been sitting that long and uncared for, I wouldn't expect is worth more than $1,500 - 2,000 tops, and only then if the engine isn't stuck, there isn't extensive rust, and it's complete.
HermanTheGerman
12-28-2014 03:16 PM
gcorse
03-12-2013 05:13 AM
havi
11-14-2005 10:40 PM
